Brake recommendations...
Old Feb 16, 2007 | 09:21 PM
etggolf's Avatar
etggolf
Default Brake recommendations...
Just found out the rear brakes of my SC400 are leaking... trying to avoid the "stealership" whats out there so I could buy online and have the local Toyo/Lex shop do it for me..?
Old Feb 16, 2007 | 10:02 PM
Baoser's Avatar
Baoser
where is it leaking from?
Old Feb 22, 2007 | 01:57 AM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Check prices at AutoZone for rebuilt calipers. Calipers are easy to swap out.
Old Feb 22, 2007 | 12:13 PM
T0ked's Avatar
T0ked
Or you can buy a rebuild kit from toyota for around $30. They send you all the rubber parts and washers to rebuld it yourself.
Old Feb 22, 2007 | 06:56 PM
JohnEd's Avatar
JohnEd
Default caliper rebuild
I have rebuilt a ton of brakes. If they leak there is corrosion of the cylinder for drum brakes and for discs the piston and cylinder are pitted. MOST PROBABLY. This is a generality. You needto get feedback from this forum to decide if a rebuild works in most circumstances. $30 for a kit and $70 for a rebuilt, I would go with the rebuilt unless I got feedback that the kits work almost always. New is stupid! Worn pistons are prone to brake squeel and you haven't lived till you have that problem with a luxury car.
My .02 cents
John
Old Mar 2, 2007 | 12:38 PM
aliga's Avatar
aliga
Former Sponsor
i have front calipers or upgraded ls400 calipers, if you need them.
RRRacing
GX - 1st Gen (2003-2009)
20
Jul 30, 2024 07:55 AM
peasodos
Jun 23, 2017 12:36 PM
vintagelex
Jul 15, 2014 11:32 AM
2OnyxLexus
Mar 12, 2012 12:16 PM
MIA2GS
Suspension and Brakes
May 20, 2011 06:43 AM
