built w58??
Old Feb 13, 2007 | 11:32 AM
SC300_704's Avatar
SC300_704
Default built w58??
is building an w58 transmission cheaper and more reliable if possible or do you rather get an 6 speed tt transmission...
Old Feb 13, 2007 | 07:05 PM
Willicuddy's Avatar
Willicuddy
Rebuilding a W58 is gonna be much cheaper then swapping in a 6 speed, but the 6 speed will obviously be able to handle more power then the W58....... How much power are you pushing??
Old Feb 13, 2007 | 09:02 PM
bens sc's Avatar
bens sc
v160/161 ftw
Old Feb 14, 2007 | 12:18 AM
SC300_704's Avatar
SC300_704
my goal is to be 500hp street car..just wanted to know.
Old Feb 14, 2007 | 08:03 AM
MDeezy's Avatar
MDeezy
I cant remember the level of difficulty in installing the 6spd, but the price of a 6spd (from what I've seen), could easily leave you with change after a w58 is beefed up.
I'd take the w58 beefed up.
Old Feb 14, 2007 | 08:05 AM
vipsoarer's Avatar
vipsoarer
the real issue is who can/will build the w58?... the answer is you either have to go fully custom internals or cryo-treating thus far. so unless you want to spend the cost of 2 v160's for custom internals or cryo your gears and make them brittle with only marginal gains you wont be better off building the w58.
Old Feb 14, 2007 | 08:16 AM
MDeezy's Avatar
MDeezy
well if the rebuild will be more expensive. then the 6spd is the better choice. especially since its built to handle much more power.
Couldnt the w58 just be rebuilt with new gears synchros and cryo treat it? why would custom internals be needed?
Old Feb 14, 2007 | 11:13 AM
David_K's Avatar
David_K
Get a TKO and that bellhousing from that Aussie company
Old Feb 14, 2007 | 01:05 PM
5spdSC300's Avatar
5spdSC300
IIRC, there is a member on the supra forums that cryo treated his w58 gears when he did a rebuild and all that did was prolong the damage from happening sooner. The extra time that the tranny lived was not very long and not worth the extra money of cryo treating.
PPG sells a set of dog engagement gear set that should handle whatever you throw at it but msrp is $7500AUD which comes out to about $5800. This is the only w58 upgrade i know of.
Old Feb 14, 2007 | 01:34 PM
dejacky's Avatar
dejacky
Just use the R154 transmission with a 1JZ bellhousing...fits better, 5 gear trans that lets u keep your stock final drive ratio, lighter than the getrag trans but stronger than a w58..also much cheaper than getrag swap.
Old Feb 14, 2007 | 02:25 PM
qksl2's Avatar
qksl2
How strong exactly is the r154? I am debating between the v160 and the r154. Looking for more than 500whp, though.
Ian
Old Feb 14, 2007 | 04:00 PM
dejacky's Avatar
dejacky
Ian
Folks have been running 650rwhp with the BoostLogic R154 kit daily driven with no problems. It's significantly stronger than the w58 trans and cheaper than the getrags..much cheaper.
Old Feb 14, 2007 | 10:43 PM
SC300_704's Avatar
SC300_704
i always get confuse on the term r154..is it from the 1jz or from the 7mgte??
Old Feb 14, 2007 | 10:52 PM
qksl2's Avatar
qksl2
It's from either, though they are different and teh 7mgte version from the mk3 requires modification to the shifter, I've read, to move it back.
Yeah thats what I've been reading. Anyone know the max that you can put through it? I'd like to couple it with a rear end witht he long gearing like the tt lsd's. Thoughts on that?
I have found that you can put in an r154(modded shifter)or an auto tt diff, but what if you want long gears and the r154?
I'll keep searching,
Ian
Old Feb 15, 2007 | 04:37 PM
atekt's Avatar
atekt
mmmm... I am looking for the same thing. Ill stay tuned in.
