What to do with old calipers.
Old Dec 9, 2006 | 06:54 PM
T0ked's Avatar
T0ked
Default What to do with old calipers.
Ok, so I just got my rear calipers and rotors changed. Both rear calipers were seized (sliding pins were really in there, one on each side). I figure the rotors are junk and so will toss them. Is there anyplace that I can do a core exchange with these calipers? Maybe get refurbed ones for these? or should I just junk these also?
Old Dec 10, 2006 | 04:52 AM
morris's Avatar
morris
Advance autoparts will require the old calipers from you as a core for some new ones. Of course you also have to pay for the new ones.
Old Dec 10, 2006 | 12:09 PM
mobilyte's Avatar
mobilyte
there is no need to replace the caliper if just the sliding pin is seized. remove the sliding pin and lube the heck out of it. if the pistons in the calipers were seized, then replace with reman or get the rebuild kit from the dealership for $30.
sounds like you've already replaced the calipers, just keep the old ones as spares. use a c-clamp to see if the piston can be pushed back. push them in to drain as much of the old fluid out as possible. if they've been removed off the car, now is also a good time to make sure the bleeder valves can be loosened. bag em and set them aside for a rainy day.
Andy2675
GX - 1st Gen (2003-2009)
May 10, 2019 11:03 PM
cssnms
Oct 11, 2018 07:44 AM
Hoovey689
Jan 25, 2018 12:07 PM
MrGalione9
Jul 21, 2009 07:55 PM
GSing430
Suspension and Brakes
Aug 17, 2007 01:52 PM
