well some issues that most people run into while swapping their engines is that they get the wrong "sump" location for their cars. so basically depending on what production year your car is, try to find a swap that applies to your year vehicle.
guys you can pass emissions when its time to do so jus swap back the stock engine for inspection.with the right tools pulling the engine out should only take 2-4 hours .obd2exists all over the world not only in north america .if u get a 97+1jz it will work fine .dont know if it will pass inspection tho .(maby thats why it never came to america) but there is obd2 1j's .its jus locating one
OK say i Buy a 94 JDM Aristo 2JZGTE from japan, put USDM spec turbos, cams, injectors ect and the USDM harness and ECU from a 97 OBD supra, will that pass the OBD2 plug in emissions?
Originally Posted by mr2turbo12
if it wasnt for emissions id have a 1jz in my 97 SC already. Only way around emissions is 96+ 2JZ-GTE swap with ecu or NA-T.
You guys are so gullible. There are plenty of us running around here in IL without worries. IL is not CA. Not to mention why would you go with 1JZ if you can turbo yours or go with 2JZ-GTE.
I have a JDM 2JZ-GTE motor (without EGR) running aftermarket (as in not Toyota) OBD-less ECU in a 97 SC300.
Chris
do you not have emissions testing there?
here in Nevada if you live in Las Vegas or Reno you are subject to passing the obd2 test, however, if you live outside Clark County or the country Reno is in, you don't have to have it tested at all...
We do only in and around major cities, but even then it's not the end of the world. There are ways to get around them.
I work at a smog inspection station... I know there are ways around them...
But, not everyone has that kind of hookup...
Do you know hook ups? I might pull the trigger and buy this Sc with swap 1jz in it. But I don't know that kind of hook up for smog. He can't pass it legally in cali. Sorry for bringing back the thread Lol
