Problem with your Diff or driveshaft bushing?
Old Nov 2, 2006 | 04:20 PM
bunta's Avatar
bunta
Default Problem with your Diff or driveshaft bushing?
i did a few research but wasnt able to find anything, the main concern is the driveshaft bushing, its made out of rubber, anybody with some power or a diff can possibly brake it by kickin the clutch to go sideways, anybody know any company that make a better bushing or metal/urethane bushing for the drive shaft? like this for the S/C previa? please help thanks
Old Nov 2, 2006 | 07:17 PM
SupraCoup3's Avatar
SupraCoup3
I haven't heard of any issues relating to drive shaft bushings. Typically it's engine & tranny bushings that get replaced with TRD variants from the MKIV Supra at higher HP levels.
Old Nov 3, 2006 | 06:08 AM
gadgetSC's Avatar
gadgetSC
There have been a few of us who have shredded those rubber couplers. I went through a few after installing a TRD LSD and wider tires. I was using the SC400 drive shaft and couplers. I ended up swapping in a 1 piece drive shaft that had steel couplers on each end. If I remember right, member AWJ also had a problem like this.
Anyway, those couplers in the pic look like a better replacment for the stockers under higher hp use.
gadgetSC-t
Old Nov 3, 2006 | 09:45 AM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
Use a true 100-150hp Nos system for two years and you will see damage..I had to rebuild my driveshaft from the pounding of nos in combination with the Dragon Torque Converter...
Old Nov 3, 2006 | 10:46 AM
bunta's Avatar
bunta
gadgetSC-t
is that the custom driveshaft with the metal couplers? or ... cuz my fren has a welded diff too, and he broke the rubber piece and it seems pretty weak.. i guess its for comfort since alot of other cars does not have bushing between shaft and diff?
so any other options besides the weak stock bushing?
Old Nov 3, 2006 | 10:52 AM
bunta's Avatar
bunta
cheap options please.... can not afford a custom ds >_<
Old Nov 8, 2006 | 02:22 PM
bunta's Avatar
bunta
ttt to the top
jdm93400
Sep 5, 2018 07:40 AM
ls400love
Suspension and Brakes
Jul 24, 2014 07:05 PM
NomShark
Jan 28, 2014 04:04 PM
snakehead
Oct 21, 2012 06:41 PM
ConSynX
Dec 30, 2011 05:36 PM
