Swooshing Noise When Throttling?
Old Oct 10, 2006 | 03:41 PM
Noonan's Avatar
Noonan
Default Swooshing Noise When Throttling?
Recently purchased a 96 SC400 with 72k on it.
After picking it up from the dealer, I thought the brakes needed to be replaced because I heard a scraping/swooshing noise. Took it to a shop, it needed brakes so I had them replaced. After driving home from the shop I realized that it wasn't the brakes (although they were due for replacement). Whenever you give the car gas, you can hear a swooshing/scraping noise. It also happens when you rev the engine.
What could it be?
Old Oct 10, 2006 | 06:04 PM
rcracer_tx's Avatar
rcracer_tx
Hopefully its not one of your tie rods, but at that mileage that shouldn't be your problem
Old Oct 10, 2006 | 07:05 PM
Noonan's Avatar
Noonan
I doubt its my tie rods. I am thinking its a belt- but I am still hoping its my brakes lol
Old Oct 10, 2006 | 10:32 PM
neurocity's Avatar
neurocity
Not quite my tempo
Could it be that goofy-*** cooling fan SC400's have.
Sounds like your fan,
Get someone to rev your car while you listen (with the hood open )
Check that fan out. Be careful it doesn't fly off and Give you Crew Cut, eehhh
Old Oct 11, 2006 | 08:16 PM
Noonan's Avatar
Noonan
Is it called a fan shroud? My neighbor said it sounded like a "fan shroud" dunno what it is, is it an easy fix or does it need an entire replacement?
Old Oct 11, 2006 | 08:30 PM
neurocity's Avatar
neurocity
Not quite my tempo
The fan shroud is "around" the fan, its so people like your neighbor arent walking around with 2 fingers on each hand.
The shroud doesn't move, it may be bent and rubbing the fan, but most likely that would sound different and you'd have a nice plastic smell.
Old Oct 11, 2006 | 08:44 PM
Noonan's Avatar
Noonan
Thanks for the information.. Im going to have to figure this out. Hopefully its not expensive.
Bedore
May 10, 2011 08:19 PM
IluvS600
IS - 1st Gen (2001-2005)
Apr 20, 2010 09:54 AM
GirlDriver
Suspension and Brakes
Apr 1, 2010 05:23 PM
lx470man
IS F (2008-2014)
Feb 19, 2009 11:07 AM
