SC400 hesitation
Old Jan 1, 2007 | 03:37 PM
sc400CTI's Avatar
sc400CTI
My bad its called "Right ignition coil" The same thing happened to me at 1500-2000 rpms. Started off very mild an progressively got worse. When I unplugged the MAF the car ran fine. I changed the right ignition coil and problem solved. If the car runs rich, my guess would be the ignition coil. I had a 3,000 rmp hiccup and that turned out to be a damaged crank position sensor wire (coming off the right distributor).
Old Mar 23, 2007 | 06:45 PM
wyaaj812's Avatar
wyaaj812
any updates on this thread? Anyone find out if their crank position sensor wire was damaged?
or isn't it the cam sensor wire you're talking about sc400CTI?
NiceSC400
May 14, 2013 08:17 PM
mohamed196
Jun 18, 2012 02:08 PM
over40driv
Jul 2, 2007 06:08 PM
stokdd
Nov 16, 2006 05:35 PM
burnettebr
Maintenance
Sep 25, 2003 08:26 AM
