Injector Questions?
Old Sep 17, 2006 | 04:08 PM
lpolo69's Avatar
lpolo69
Default Injector Questions?
ANyone running mkiv supra USDM 550 on their 1jz ...if so ..Are they drop in? OR do you need to do some mods???
Old Sep 18, 2006 | 12:40 PM
5spdSC300's Avatar
5spdSC300
You will need to wire in a resistor pack to run the usdm 550's. The jdm 2jzgte 440 injectors would be drop in with no issues. You will want some type of fuel controller or you will run rich.
Old Sep 18, 2006 | 09:26 PM
lpolo69's Avatar
lpolo69
so in order to run the 550 i would need a Fuel pressure regulator, i wire in a resistor pack???? which one is recomended??? Will dsm ones work? OR what else///////
Old Sep 18, 2006 | 10:35 PM
5spdSC300's Avatar
5spdSC300
Im not sure, check with the 1jz guys on supraforums.
Old Sep 19, 2006 | 08:38 PM
1JZ LOL's Avatar
1JZ LOL
USDM 2JZGTE MKIV 550's are drop in, but you have to shave the clips a hair on the injectors for a good snug fit.
Buy new o-rings. $26 from toyota.
You will need to wire in a resistor pack. Mkiii one is good and small, can be hidden under intake manifold.
Stock FPR is perfect, but you will need at least an SAFCII. You can find em used all over for $200 or less.
MKIV JDM 440cc injectors do not need the resistor pack.
On a 1JZGTE, you can figure around 1WHP per CC at 100% duty cycle.
No matter what you do, with a single setup, youll need basic fuel managment, like an SAFC2, proven to put 1JZGTEs in the 500+whp range.
xspsi6
Feb 10, 2014 06:25 PM
got-sc?
Feb 24, 2010 04:10 PM
Biggu
SC400 / 300 Classifieds
Aug 27, 2009 09:50 PM
scturbo28
May 14, 2009 08:30 PM
VGnomore
Mar 18, 2006 05:50 PM
