twin turbo upgrade
Old Sep 16, 2006 | 07:41 AM
1JZ300's Avatar
1JZ300
i was thinking about 400 streetable, 625 is a little more than streetable, thinkof 625 when its raining and its your everyday driver, you need to switch lanes so you go to turn and some guy is coming up quick, so you hit the gas a ltitle, and being an auto it downshifts for you and you spinn out cuz the 600 hp is letting loose on the wet road....600 is not streetable
Old Sep 16, 2006 | 11:53 AM
JJG2005's Avatar
JJG2005
650hp is very streetable... it's just not able to be your daily driver, or driven easily in the rain or the snow. There's definately a difference.
Old Sep 16, 2006 | 03:01 PM
1JZ300's Avatar
1JZ300
true true, i agree, i thought he meant daily driver....not just street legal....good call though, it is streetable
Old Sep 16, 2006 | 06:27 PM
morris's Avatar
morris
Thats true I consider my car to be a daily driver just not when the temperature is under 45 degreees.
It gets loose to easily.
Old Sep 19, 2006 | 03:54 PM
Notorious's Avatar
Notorious
Back to the core of the topic though...
Does anyone know of a good bolt on twins setup for the 1JZ?
How about the USDM supra twins? They're a bit bigger than the 1J twins, aren't they? Do they bolt right up? Are they good for more power?
I think my stock 1JZ twins may be on their last leg. Without having to move to a new exhaust manifold, are there options for more power?
Second question: If I convert from stock twins to a single turbo, what do I need to get and what is a good turbo recommendation for a streetable SC. I've got 300+ to the wheels now and I want more, but I love the lack of turbo lag on the stock twins. I know I'll need a new exhaust manifold and a turbo... what else? As for turbo, what's the hot setup for no lag and good power on the 1JZ? Garret GT series?
TIA,
Marcus
Old Sep 20, 2006 | 05:43 PM
Durrr's Avatar
Durrr
CL Folding 25,000
you could just turn down the boost when in bad weather, aka, EBC
Old Sep 21, 2006 | 07:08 PM
boostedny's Avatar
boostedny
Im not to sure about that I heard that htere something like that on a few race cars..but not sure how much that programming would cost..I was looking at the hks (2835) twin turbo upgrade..is says jsut with the bolt ons its good for about 700 wheel horse..but the kit comes with manifolds and everything..and the kit goes for about 8k...would gt2835 kti on the stock TT manifold
Old Sep 21, 2006 | 07:19 PM
soardrft's Avatar
soardrft
i am also looking into a twin upgrade, but for the amount of time i have put into it there is no twin kit that will put out 650+. i was just at a shop and saw that hks kit. its for the chaser and be ready to spend a pretty penny (8700 for a kit that has to be modified w/o engine management). i also called blitz and that will only put you in the 400hp range (you can get to 600, but i have yet to see a good tunning shop). so i was told to call xs-engineering and they are moving but once the move is complete i will be stopping by (unless my fab guy gives me a deal i can't pass up). so far the solution for me is to get the k26 turbos and fab the mess out of them to fit pretty since the car needs turbos asap. there is a guy on the sf forums putting down 477hp with the same setup and he is at low boost. the other guy is around 523hp and they have dyno sheets to prove, however i don't need more than 450hp to keep my car sideways.
Old Oct 3, 2006 | 06:03 AM
96gti2.0t's Avatar
96gti2.0t
600 streetable would be great
Old Nov 16, 2006 | 06:15 PM
DoMaMuy's Avatar
DoMaMuy
Try GT32-55's.
Old Nov 16, 2006 | 06:33 PM
lemmiewink's Avatar
lemmiewink
http://mkiv.supras.org.nz/articles/hpi12_1.htm
check this out.. says something bout twin kkk k26 pushing 500 i think on stock everything but turbos
954soarer
May 19, 2008 04:29 PM
100mgbluep
SC400 / 300 Classifieds
12
Mar 13, 2008 08:47 PM
ca18det
GS - 1st Gen (1993-1997)
Mar 4, 2006 02:37 PM
Mullet
Performance
Nov 13, 2003 05:32 PM
