No power steering, fluid erupts? HELP!
Old Jan 1, 2008 | 06:28 PM
96dtm850's Avatar
96dtm850
Originally Posted by sc250tt
You guys need to wire up the PPS. Without PPS (progressive power steering) the steering will always be hard no matter what you do .The powersteering system is controlled by a computer that monitors the speed which adjust the steering pressure at high / low speeds.the faster you go the harder it gets , the slower you go the softer it gets.
Is that the big ol' connector thing that's near/under the oil filter on the SC300??? As far as I know, it was never connected and I don't see any wiring around the area that might have got disconnected or broke off. What year does the SC300 have the PPS? Theres another connector on the rack that IS connected. I believe that is the sensor/actuator with the screen that everyone talks about. Again, that is connected.
Any pics of this PPS unit on the rack?
Thanks,
Ken
Old Jan 1, 2008 | 07:20 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
Originally Posted by 96dtm850
nah, fluid is not foamy. In fact, doesn't even look like its moving around with then engine running. However, if i put my hand over the reservoir with the cap off, engine running, I can feel the suction, so I assume the NEW pump is working. I just had it in the air and turned the wheel left right for for a good 25+ times each way, held for approx. 3 seconds and still nothing. Looking at the rack, I JUST noticed on the passenger side, the boot has a small tear and some fluid is coming out. So looks I'm looking for a rack anyways. Hopefully this will solve everything.
I was replying to the OP.
ls430lover
Sep 12, 2018 08:47 AM
RuninRoach
Dec 4, 2014 05:13 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
Feb 12, 2009 10:05 AM
additude
Sep 24, 2003 09:12 AM
