Spark Plug wire removal SC400
Old Jul 30, 2006 | 08:46 AM
aftv's Avatar
aftv
Default Spark Plug wire removal SC400
I have 93 SC400 I want to change the spark plugs but cannot get the Spark Plug wire off..do you have to twist or push in and twist to get them off or what..Thanks for any help with this DUMM ?
Old Jul 30, 2006 | 09:04 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
if they've been on there a while, you just need to pull harder - the rubber boot sometimes gets stuck to the inside of the hole...
on a similar note, anyone have good experiences with aftermarket plug wires? what fits?
Old Jul 30, 2006 | 09:15 AM
aftv's Avatar
aftv
Im not sure but I think the wires I have on mine are aftermarket type and I also think they are much inferior to the OEM's because of the problem I'm having with them..the rubber grommet separates from the center wire at the top and there is nothing to pull on..because the top grommet is not connected to the center part (if you can understand what i'm trying to say)..then once that is off and you try to pull on the wire housing all it wants to do is break off in little pieces..WONDERFULL!!
Thanks for your reply...
Old Jul 30, 2006 | 09:17 AM
aftv's Avatar
aftv
P.S..I think I'm going to need a BOOT Puller,,before I really mess things up....
Lobstaman
Jun 21, 2017 01:40 PM
Lexscme
Oct 17, 2009 07:04 PM
baekpro
Jan 26, 2009 08:00 AM
1sxyrxy
Jul 8, 2008 09:44 AM
