Lexus Sc400 Nitrous
Old Jun 13, 2006 | 02:22 PM
Sc400BMORE's Avatar
Sc400BMORE
Default Lexus Sc400 Nitrous
ok so currently I purchased a brand new in box Cry O2 intake system by DEI from a buddy for $100. I am not to interested in running co2 on my sc, but would like to run a dry nitrous system. My question is can I somehow convert my Co2 system to a dry nitrous system. If so what else do I need to purchase for the system, and if not what parts could I salvage from the Co2 system. Any advice is apprectiated.
Cry 02 system includes-
1. 10 lb Tank
2. Two mounting Brackets
3. Cryogenic Solenoid Valve
4. 1/8 to 6an male fitting
5. 14 ft stainless steel Braided Hose
6. Microswitch ( full wide open throttle switch)
7. Prime Button
8. Activation Switch
Old Jun 13, 2006 | 03:40 PM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
Need -
1) 10lb nitrious botttle...
2) Walbro electric fuel pump
3) Piggyback ECU (optional but recommended to help max the fuel output and also help run the car a little rich which is a safe gaurd with nos)....
4) Heater core
That is about it....If you have the cyliniods and arming box I think you are good...
I have the 100-150 nos dry system on my 1992 SC400 for over a year and love it.....
Old Jun 13, 2006 | 03:44 PM
jibbby's Avatar
jibbby
Mount the bottle in the trunk like so and you are good too go....
Old Jun 13, 2006 | 03:46 PM
jibbby's Avatar
jibbby
The best place for the arming box is here...
Hope this helps....
Old Jun 13, 2006 | 04:44 PM
Sc400BMORE's Avatar
Sc400BMORE
Default sc400
Thanks that did help, just I hope most parts on the dei co2 system are the same as a nitrous system, like the solenoid and all. and by arming box do you mean switches? but so far this has helped alot and i like your setup on your car.
once I have it installed though, will I have to get new fuel line and fuel injectors, and since my compression ratio is 10.:1 is that to high to run a 125 shot
KOKISF
IS F (2008-2014)
Mar 16, 2014 02:17 PM
JesLet
Maintenance
Feb 10, 2014 12:38 AM
DemosISF
IS F (2008-2014)
Feb 17, 2010 11:38 AM
I8ABMR
Mar 12, 2008 10:27 AM
