More MPG Help
Old May 26, 2008 | 10:25 PM
818sc400's Avatar
818sc400
will getting a new fuel pump help?
Old May 27, 2008 | 09:58 AM
Curry's Avatar
Curry
CL Folding 25,000
Check out your fuel filter if anything.
Old Aug 6, 2008 | 05:11 PM
bspecmr2's Avatar
bspecmr2
My 96 SC300 tends to like my driving style and on the first trip out of town, from San Diego to San Fran (500 miles on the dot) it managed to pull 27mpg.
On the trip back, with the same conditions and staying within the speed limit (65-70 depending on the location) it averaged 29mpg.
The car has not had a tuneup in who knows how long. It still has the original spark plugs, wires, cap, rotor, and the air filter is dirty. The tires are underinflated as well.
Like Kaydee said a few posts up, it's all in your driving style. The car is capable of burning a little less fuel, if you're willing to sacrifice some acceleration.
I'm currently testing fuel economy from work to home, which is not exactly a 100% highway trip, and I assume that will yield worse numbers (maybe in the 22,23mpg range).
A good tuneup, starting with air filter, fuel filter, spark plugs, plug wires, distributor cap and rotor, oil change, coolant flush, properly inflated tires, and removing all the junk we tend to lug around with us, should improve the gas mileage on any vehicle. With all that said, we can't keep you off the gas pedal, so in the end it's all up to the driver.
Old Aug 13, 2008 | 09:19 PM
bspecmr2's Avatar
bspecmr2
Just a quick followup on my previous post.
Filled up tonight and mixed city/highway driving yielded 24.7mpg. Needless to say I am happy with the way I drive this car, and the way it treats me back.
Old Aug 14, 2008 | 08:30 PM
CBK's Avatar
CBK
also dont fill up your gas tank to the max its allot of extra weight
i just bought my sc400 like 2 weeks ago it drives great but the gas burns allot faster then i exepected , so how many gallons of gas does the sc max out at ?
Old Aug 14, 2008 | 08:34 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
21.6 Gallons.
Right now I'm at ~380miles give or take 5 miles, and the light isn't even on yet. Driving conservatively will yield you the best results.
Old Aug 14, 2008 | 09:01 PM
CBK's Avatar
CBK
to fill up my car from empty will cost me about 115 to 120 $ on premium gas , i dont know why some people cheap out and put regular gas , but thats not the point anyways 120 $ with my old car mazda protege 95 , i know its way smaller car but i would pass like a month and some change with that much gas money going to work and back . so i figure if you like pushing the gas allot then your gonna waste like 250 per month on GAS and thats retarded so drive normally and less often if you could , also does it matter that the car is a 92 ? they say the older the car the less mpg you get
Old Aug 15, 2008 | 01:07 AM
MT Photo's Avatar
MT Photo
I'm averaging 18 in the SC400 with a crapload of stuff in the trunk, low if anything tire pressure and not always light driving.
Don't know what's up with that.
I'm thinking about driving like a granny for one tank to see if I can break 20.
This is ALL city driving too, probably with clogged cats.
I have no idea how i'm getting such good mileage.
Old Aug 15, 2008 | 07:02 AM
redsc400's Avatar
redsc400
how much does gas cost in canada?
at $5 a gallon, youd get 23 gallons for $115....
Old Aug 15, 2008 | 04:30 PM
CBK's Avatar
CBK
a gallon here would cost 5.10 $ so full tank about 115 to 120 still its allot for gas
i hope after i get all the oils , filter ...... all get some more mpg if not well all b driving real slow but gotta do something about the acceleration its slow unless you floor it
Old Aug 15, 2008 | 11:04 PM
MT Photo's Avatar
MT Photo
Costs $69.50 for me usually.
Old Aug 17, 2008 | 09:54 AM
VJZ's Avatar
VJZ
I have a K&N drop in and cut off mufflers.
On the way back from TN I knocked down 27.5 on the highway driving conservatively.
If you have larger rims your trip ODO will be off a bit. Fortunately we had a Prius with us with no mods...so we used that mileage from point a to point b
If I go by my ODO its about 25 MPG
And I don't even have my Magnecore wires or platinum plugs yet!
Old Jan 22, 2009 | 06:29 AM
dunahoo's Avatar
dunahoo
I just replaced my o2 sensors and I am getting 10mpg... im pretty irritated cause I do not know what to do... the car runs fine and great, but terrible gas mileage and I do not have a lead foot...
Old Aug 25, 2010 | 03:32 PM
nathan1352's Avatar
nathan1352
I have a 92 that I'm getting 22.5 mpg out of right now with "spirited" driving. I have a AEM cai, electric fan, muffler cutoff, and spare tire removed. The motor was just replaced with one that had 73k on it and it idles rough (I'm guessing I got a vacuum line messed up. Another thing to look into to get better mileage is your motor oil. I use Royal Purple full synthetic and I've seen 2-3 mpg before on some of my other cars and even gotten better than factory rating on some at over 100k miles.
Old Sep 27, 2010 | 06:02 PM
jpvarghese's Avatar
jpvarghese
I had to bring this thread back up and am ecstatic about my gas mileage. Overview: VVt-i, 6-cylinder, and 151,000 miles. Recently, I switched over to Castrol High Mileage oil and had the plugs and ail filter changed about 20,000 miles ago. I also replaced the y-pipe with something less restrictive and stock diameter. With 80% hwy and 20% city, accelerating/decelerating with the cruise control and braking only when necessary, my combined gas mileage has been 27.3 mpg. My best highway mileage has been 30.4 mpg averaging 55 mph for over 45 minutes straight. I think I can hit 500 miles to the tank by the end of this week. This is purely experimental, and unless you want to **** off other drivers or don't have any patience, I wouldn't recommend it.
sam555
24
Jan 15, 2019 10:38 AM
PirelliRC
May 15, 2015 10:00 AM
almost_g
Nov 19, 2007 07:13 AM
GFerg
Nov 17, 2005 10:17 PM
fillup
Sep 14, 2005 09:56 AM
