Started my 6 speed conversion today...
Old Feb 24, 2006 | 06:15 PM
Coastal's Avatar
Coastal
1 more of the damage
Old Feb 24, 2006 | 06:16 PM
Coastal's Avatar
Coastal
roll pins backing out of the shift linkage, a common problem in these transmissions.
Old Feb 26, 2006 | 08:00 AM
Todd1225's Avatar
Todd1225
Thanks for sharing! I'm planning to go this route soon as well. Any details,prices, problems are always welcome!
Old Mar 1, 2006 | 01:36 AM
Arizona's Avatar
Arizona
Coastal-
When actual conversion process(ie setting up chassis for swap) begins be sure to post what parts and processes were needed and done. This would be a good search refrence point(maybe sticky) for future members.
Nice thread so far, not many people know of the internal workings and issues of a transmission. Good post.
Old Mar 1, 2006 | 06:34 PM
Coastal's Avatar
Coastal
Originally Posted by Arizona
Coastal-
I'll be taking pics throughout the entire process, mostly during the swap, I also have a parts breakdown on the Lexus parts needed, I'm buying all new parts which made it a bit easier, but getting all the part #'s togather was a pain in the a**. I'll post up a scan of the schematic soon.
Old Mar 1, 2006 | 06:36 PM
Coastal's Avatar
Coastal
the tranny parts came in today, rebuild pics tommorrow!!
Old Mar 1, 2006 | 06:38 PM
Coastal's Avatar
Coastal
also started on the supra TT diff today, i should of took before pics, nasty!! this is after degrease and pressure washing. i will also be pulling this apart for a check up.
Old Mar 2, 2006 | 07:03 PM
1sxyrxy's Avatar
1sxyrxy
are you going to need the 6speed ecu?
Old Mar 2, 2006 | 08:01 PM
Coastal's Avatar
Coastal
no, ill be using AEM, but even so the 6spd ecu is not needed.
Old Mar 2, 2006 | 08:03 PM
Coastal's Avatar
Coastal
tranny going back togather
Old Mar 2, 2006 | 08:04 PM
Coastal's Avatar
Coastal
rear case back on
Old Mar 2, 2006 | 08:05 PM
Coastal's Avatar
Coastal
took the diff apart for a quick check, found a few worn spots on the ring gear and a couple worn diff gears, but no major damage. these need to be checked for chipped teeth and possible cracks in the diff gears.
Old Mar 2, 2006 | 08:06 PM
Coastal's Avatar
Coastal
sand blasted the front cover, looks like new!!
Old Mar 2, 2006 | 10:21 PM
1sxyrxy's Avatar
1sxyrxy
did you order each part one by one or did you buy a kit for the tranny?
Old Mar 3, 2006 | 07:06 AM
Coastal's Avatar
Coastal
had to order each part, i will post a breakdown in a day or so.
