Check Engine Light
Old Feb 6, 2006 | 08:27 AM
b1ackhawk's Avatar
b1ackhawk
CL Folding 3,000,000
Default Check Engine Light
I have a 95 SC 400, pretty much stock. Ever since I purchased the car over 2 years ago, I have had an interesting, im not going to say problem cause i havent really had a problem, but indication, maybe??? Every once in a while the check engine light will flash on for maybe 3-5 seconds then shut right off. It is not a very common occurance, sometimes months will pass with out seeing it. Like I said, ive had no problems really, maybe a little idle temperment, but nothing that akward.
The car is obviously OBD1 so I dont know how much a computer check would help. Does anyone know if the check would pull up any codes if the engine light is off? Like I said, the light turns off after 3-5 seconds, so its practically impossible to test it when the light is on.
Any ideas?
Old Feb 6, 2006 | 10:56 PM
hotttoddie's Avatar
hotttoddie
http://www.troublecodes.net/Lexus/
check that... you should still be able to get the last couple codes in the computer if they were truly valid - could be a faulty connection though.... let me know what it says... i have the entire repair manual in pdf and can tell you how to fixe each code...
melissac
Jun 30, 2009 04:50 PM
garcia5280
Apr 10, 2009 10:43 AM
DJ TANTRA
NELOC
Sep 2, 2007 07:46 PM
smuv gs3
GS - 1st Gen (1993-1997)
Dec 17, 2005 08:15 AM
