tranny ?
Old Jan 20, 2006 | 05:22 PM
alanhp's Avatar
alanhp
Default tranny ?
I want to rebuild my gear box. I d like to do it myself. Not sur if it is worth it. Or should i buy a rebuilt one. I also want to change my rear end. Is there any other lexus rear end that i can use. Or can i make my old one into a limted slip.
Old Jan 21, 2006 | 05:29 AM
nasc300's Avatar
nasc300
if it's an auto
http://www.importperformancetrans.co...uto.shtml#main
Old Jan 21, 2006 | 06:04 AM
morris's Avatar
morris
So is the kit something that a shade tree guy can buy and successfully rebuild there tranny?
Old Jan 21, 2006 | 06:32 AM
alanhp's Avatar
alanhp
Default Manual
Its A Manual. There Is No Kit That I Now About Yet. I Was Wonder If Anyone New About A Kit. I Am A Mechanic So I Shold Be Able To Do It.
Old Jan 21, 2006 | 06:48 AM
Rising_Sun's Avatar
Rising_Sun
The W58 manual tranny is the same as the Supra NA tranny. But it only holds to about 450 HP. If your looking to make more power eventually, you're better off finding a R154 tranny from a Soarer. It's direct fit and holds twice the power.
Old Jan 21, 2006 | 07:50 AM
vipsoarer's Avatar
vipsoarer
rising_sun is correct, if you plan on running an lsd on the w58 be very cautious as the tranny does not like them on a 400 hp application. rebuilding the unit is as easy as rebuilding any trans just make sure to double check all your clearances and make sure all your torque settings are correct.
warreng
Nov 7, 2013 08:43 PM
Shyne
Performance
Nov 1, 2004 11:24 PM
Hermosa
Aug 29, 2003 03:49 PM
