2jzgte swap info/pricing
Old Jul 27, 2006 | 02:59 PM
RS3's Avatar
RS3
Originally Posted by hemogoblin
I have pretty much all the USDM conversion parts and ive spend around $1800-3000. Im not quite sure.. They are fairly cheap by themselves, but when you add them up its scary.
I bascially have everything except the motor.
Let's do the math:
Motor with unknown history & broken second turbo: $1850 shipped
USDM conversion parts: $2400 (the mean value between those "hemogoblin" produced)
Total: $4250 - not accounting for the time invested compiling the conversion parts
How is this desirable over a USDM setup with known mileage?
Cheers,
Old Jul 27, 2006 | 03:24 PM
ummagawd's Avatar
ummagawd
jeez what parts are you using to go "USDM"???
the biggest differences are turbo, intake cam shaft, turbos, and injectors.... all of which won't cost you over 1k at higher than normal pricing (used)
unless you're thinking ECU? which is pointless if you're going to use aftermarket fuel management
Old Jul 27, 2006 | 04:08 PM
mikeloc24's Avatar
mikeloc24
Originally Posted by sao1
I got mine from www.osakajdmmotors.com. I got the longblock and the complete swap for 1850$ shipped from Canada. It came with a broken rear turbocharger though, and Osaka and the shipping company aren't claiming none of them broke the turbo. So the process of getting the turbo replaced is taking 2 months and counting. I end up buying used twins from someone else to complete my project for a buddy.
If they can get their customer service taken care of, they would be in more business.
12-22-05 was the last post before yours
Old Jul 27, 2006 | 04:41 PM
hemogoblin's Avatar
hemogoblin
I got ECU and USDM Harness which was a huge chunk of that change. I also got things like Fuel pump, Fuel pump ECU, EFI pack, Ignitor, and um a few more things, I cant recall the rest right now. From what ive read you can do without some of these parts, but I just went ahead and got everything.
And I still need a few parts.
Old Jul 27, 2006 | 04:44 PM
ummagawd's Avatar
ummagawd
yea you don't need a US wire harness or ECU to make it work.... those 2 things will be a HUGE chunk!
Old Jul 28, 2006 | 11:22 AM
RS3's Avatar
RS3
Why the discrepancy in what people consider necessary to the conversion? There must be some pros/cons of using the USDM harness & ECU.
Cheers,
Old Jul 31, 2006 | 08:37 AM
sao1's Avatar
sao1
How much RWHP can the stock ECU can handle with the USDM MAF system or the JDM MAP system?
I am considering TEC3 EMS or the AEM EMS? What do you guys think. Im planning on using a GT42 turbo instead of using the stock twins before I put in the 2JZGTE. Of course the fuel system will to be upgrade also.
Old Jul 31, 2006 | 09:02 AM
hemogoblin's Avatar
hemogoblin
Cheers,
All the info you want can be found by searching here and on Supraforums. But I went ahead and got everything for the USDM swap to make the swap as smooth as possible. I basically want everything to be upto USDM spec 2J so I can goto autozone and ask for parts on a 95 supra turbo. Not be out of luck because I need a replacement JDM part or something I buy isnt compatible with the JDM motor.
The USDM 2J in stock form has 320hp, while the JDM has 280hp. If your going to go standalone, then the ECU dosent matter, and most of the JDM parts wouldnt matter. But I dont really plan on making huge power, and I dont want any headaches in the future (hence a full USDM conversion)
Old Aug 2, 2006 | 09:34 AM
plex's Avatar
plex
1UZFE/2JZGTE
There is a complete USDM auto swap on SF right now for $3K that's a good deal imo.
lequanus27
Sep 29, 2014 02:31 PM
TroySC300
Jan 8, 2009 11:29 PM
dbltakegs3
16
May 27, 2008 06:25 AM
ca18det
GS - 1st Gen (1993-1997)
Jul 25, 2006 09:12 AM
cefiro
SC400 / 300 Classifieds
May 17, 2004 10:18 AM
