Need help on 97+ Fog lights
Old Nov 23, 2005 | 10:56 PM
LexAnt's Avatar
LexAnt
Default Need help on 97+ Fog lights
Hi,
Since my car is currently in the bodyshop and I don't have access to the foglights, could someone measure the distance inside the foglight. Specifically from the base area (plug area) to the cover over the bulb itself. So if you looked at it directly, you would notice that there's a circular piece covering the bulb. From that piece to the edge where you would lock the bulb in place.
Thanks,
Anthony
https://www.clublexus.com/forums/sho...light=foglight
so from this thread you can see that the cover was taken out (pics in lex400sc's post), i need to kno the distance from that inner portion to the bulb base locking portion. I need 1 5/8" distance.
Old Nov 24, 2005 | 08:27 PM
LexAnt's Avatar
LexAnt
bump... can anyone help measure?
Old Nov 26, 2005 | 02:13 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I understand what you are going for, but these are all I have. Using pics of the lights you should be able to judge relative depth using these dimensions. Also, I see no reason why you can't find the dimensions and specs on these housings and the front clip.
O. L. T.'s Avatar
O. L. T.
Keeper of the light
phil97ES3
Jul 15, 2008 11:40 PM
slevytam
Apr 9, 2008 12:17 PM
$C300
Lighting
Feb 12, 2007 12:32 PM
chieeeeef
Lighting
Jan 16, 2006 06:08 PM
IS V300
Jul 8, 2005 02:16 PM
