Vibration
Old Nov 15, 2005 | 03:04 PM
neoprelude's Avatar
neoprelude
Default Vibration
Ever since I got my clutch installed it makes a vibration above like 75 mph, which didn't annoy me i've had it now for about 10 months and now it seems the vibrations are starting at like 60 now. I hope nothing is wrong, if the driveshaft wasn't aligned correctly or something could it eventually get worse??
Old Nov 15, 2005 | 03:25 PM
neoprelude's Avatar
neoprelude
Would this be called driveshaft bushing, differential bushing?? Or something along those lines and where can I get one at online?
Old Nov 16, 2005 | 03:26 AM
bmatsu's Avatar
bmatsu
Try re-torqueing the driveshaft bolts, when I changed my clutch, the guy said he torque the bolts but when I checked it out myself the bolts were loose.
So check the bolts, if you can loosen them easily by hand (with a socket wrench), then apply loctite and re-torque them. I think the bolts get torqued to 61lbs. (not positive)
This happened to another member a while back, and he did not know how the bolts came loose either.
It solved my problems.
Good luck
6SOARER
Apr 22, 2011 08:34 PM
Blk97SC300
Jan 30, 2008 12:47 PM
SC300_704
Jan 2, 2008 08:36 AM
