A/C system diagnostics- Need codes.
Old Apr 22, 2018 | 04:48 PM
  #61
kelleher2's Avatar
kelleher2
i get codes 21,24,28
what is 28
Old Oct 10, 2020 | 04:42 PM
  #62
Kingrb18's Avatar
Kingrb18
Originally Posted by Khaos
I was having trouble at first too. Make sure that you press the RECIRCULATION button and AUTO button, THEN turn the ignition to ON. The original post is a little confusing as to the order in which you are suppose to do the setps. Here are the full instructions:
TROUBLE SHOOTING
SELF-DIAGNOSTICS
An Electronic Control Unit (ECU) within A/C-heater control
panel monitors system circuits and stores trouble codes in memory if
problems are detected. All codes, except Codes 22 and 23, are stored
in memory. Malfunction is current if Code 22 or 23 is displayed. To
retrieve stored codes, see RETRIEVING CODES. Codes are displayed at
temperature display. See Fig. 2.
RETRIEVING CODES
1) Simultaneously press and hold AUTO and recirculated air
switches. See Fig. 2. Turn ignition on. All indicators will flash 4
times, at one-second intervals. Tone will sound when indicators flash.
2) A/C system will enter self-diagnostic mode. To end
indicator check, press and release OFF switch. Read codes at
3) If trouble code is displayed, proceed to appropriate
trouble shooting procedure. See DIAGNOSTIC CODE IDENTIFICATION table.
Codes are displayed in ascending order. To slow rate at which codes
are displayed, press fresh air button to change display to step
operation. Each time fresh air button is pressed, display changes by
one step.
4) If tone sounds as code is displayed, problem currently
exists. If tone does not sound as code is displayed, problem occurred
in past and does not presently exist.
Code Diagnosis
00 ................................................ Normal
11 (1) ............. In-Vehicle Temperature Sensor Circuit
12 (2) ................ Ambient Temperature Sensor Circuit
13 ................. Evaporator Temperature Sensor Circuit
14 .................... Coolant Temperature Sensor Circuit
21 (3) .............................. Solar Sensor Circuit
22 (4) .................... Compressor Lock Sensor Circuit
23 (4) ........................... Pressure Switch Circuit
31 .................. Air Mix Door Position Sensor Circuit
32 ................ Air Inlet Door Position Sensor Circuit
33 ............... Air Outlet Door Position Sensor Circuit
41 ....................... Air Mix Door Servomotor Circuit
42 ..................... Air Inlet Door Servomotor Circuit
43 .................... Air Outlet Door Servomotor Circuit
(1) - If in-vehicle temperature is -4  F (-20  C) or less,
Code 11 may set even though system is normal.
(2) - If outside air temperature is -58  F (-50  C) or less,
Code 12 may occur set though system is normal.
(3) - If testing is done in a dark area, Code 21 may set
even though system is normal. Shine a light at solar
sensor and recheck codes.
(4) - Malfunction is current. Code is not stored in memory.
ACTUATOR CHECK
1) Perform step 1) of RETRIEVING CODES. When system enters
self-diagnostic mode, press recirculated air button. Each mode door,
motor, and relay will operate at one-second intervals. Press fresh air
button to display codes one at a time, and perform step-by-step
actuator check.
2) Check airflow and temperature by hand. Tone will sound
each time display code changes. Each display code is associated with a
system operating condition. See Fig. 3 or 4. Press OFF button to
cancel actuator check mode.
So i got code 41. If i replace the AIR MIX DOOR POSITION SENSOR OR “THE SERVO”, my problem with the delay of my ac turning on would fix the problem?? Cause my ac on my 2011 LS460 would turn on 30-45 seconds after i start the car and my temp setting would not save the previous temp it goes back to 75 degress.
Thanks
Old Oct 11, 2020 | 12:14 AM
  #63
KahnBB6's Avatar
KahnBB6
Thanks
Kingrb18, is this in reference to an A/C Error Code 41 for your SC300 or SC400 or are you asking in reference to a 2011 LS460? This thread is specific to SC300/400's.
With these older A/C Air Mix Door servo units there is the option of replacing with a known good used unit (if no new ones are still available) and there is also a procedure out there pioneered on a GS300 that shows how to carefully recondition one of these servos.
Old Oct 11, 2020 | 03:38 AM
  #64
Kingrb18's Avatar
Kingrb18
Oh its for my LS460. Do you think this might be the same?
Thanks
Old Oct 11, 2020 | 07:47 PM
  #65
KahnBB6's Avatar
KahnBB6
Thanks
No, the system, model specific A/C component designs and climate control unit will all be completely different between a 1992-2000 SC300/400 and a 2011 LS460.
Only the general theory of how a common car A/C system is designed will be a commonality. Even then an SC uses a thermal expansion valve setup on its evaporator which is old technology that was not manufactured with a much newer LS460.
The LS460 has multi-zone climate control with a different number and design to each servo unit behind the dash. A 92-00 SC has three servos behind the dash and a single zone climate control computer.
The error codes *may* be similar between Toyota/Lexus models of the SC’s vintage and your 2011 however.
The good news is that if one of your A/C servos actually is bad it will still be available as a new replacement part from Lexus.
I suggest posting the same question again in the LS460 sub-forum where there is much more familiarity with your specific model to help diagnose your issue.
Old Oct 13, 2020 | 07:17 AM
  #66
Kingrb18's Avatar
Kingrb18
Only the general theory of how a common car A/C system is design will be a commonality. Even then an SC uses a thermal expansion valve setup on its evaporator which is old technology that was not manufactured with a much newer LS460.
The LS460 has multi-zone climate control with a different number and design to each servo unit behing the dash. A 92-00 SC has three servos behind the dash and a single zone climate control computer.
Thank you so much Kahn. Im new in the forum and i dont see a detailed post like yours with for LS’s.
Old Oct 14, 2020 | 02:24 AM
  #67
KahnBB6's Avatar
KahnBB6
First off, I should have already said welcome to CL! I wish I could help you out more with your LS460 but I'm just not very familiar with the workings of an LS of your model's generation, only the very basics. They're certainly more complicated than 90's SC/Soarers. Another main difference will be that a Lexus or any car as new as yours will have an extensive CANBUS local data network for all the ECU modules in the car to talk to each other. Further, these will be multiplexing modules which means little ECU-like units around the car may perform two or more functions. Most cars of the 92-00 SC's vintage still use individual ECUs for almost every function and those just respond to simple voltage signal wires apart from their power and ground wires.
Thus the A/C controller and A/C dash servos in 92-00 SC's are very electrically simple designs compared to what you have in your LS460.
Again, I do not know how much the old 90's Toyota/Lexus A/C trouble codes line up with an LS460's trouble codes. What I'd guess is that an LS460 may use many of the same codes but have even more of them since it's a dual zone climate system. I'm not sure honestly but apart from the forums there is one other resource that can help:
Get a 2-3 day account for the Toyota/Lexus TIS (Total Information System) website and you can access pretty much any U.S. spec model Toyota or Lexus ever sold and download the factory technical service manual pages for any sections that you will need to review for your model, make and year. It's only a few bucks and if you can get access to the same service manual pages that the technicians have, including the official troubleshooting order for all of the car's systems... such as the A/C system.
Again, I'd still urge you to direct LS460 related questions into the appropriate model sub-forum because it's not something we're as familiar with here in the 1st gen SC section but I hope this helps a little bit!
Old Oct 26, 2020 | 01:41 PM
  #68
bez88hlb's Avatar
bez88hlb
Does anyone know if there’s is a self diagnostic feature for a 2008 is250 with navigation? My motor blower is not turning on and was replaced and still not working, worked prior to going out. Fuses and relay have been changed.
Old Jul 2, 2021 | 06:08 AM
  #69
Martin836's Avatar
Martin836
Default Code 24 pls !
Code 24,,, someone can get what is it? (Not in the chart)
Nobody can help ?
Old May 22, 2022 | 12:20 PM
  #70
jadesc4's Avatar
jadesc4
Time to resurrect this thread again it’s summer time and my ac is being odd. CODES 21 and 43
Looking into the thread it seems code 43 really doesn’t matter because i can still change the location of where the ac blows. Although i must say when i put it in the face position or any other it will only blow in bi direction (face and foot).
The ac never really blew cold just air. I checked freon levels and it’s in the green. Now when i turn on the ac button the ac button blinks (that’s why i’m here) and when first turning on the ac it will blow icebergs for 1-3 seconds the rpms will drop anywhere between 900-400 and the sc compressor will make a odd metal on metal sound (hard to explain) Previously in the winter the ac blew hot air but i never pressed the ac button only the level of air being put out.
Before all this happened i’ve pressed the ac button the compressor would kick up but no icebergs only ambient air going into the cabin.
Edit: i would like to mention i just changed my throttle body gasket and valve cover gaskets. Although this shouldn’t have any sense in the coldness but possibly the new “metal on metal” like symptom that has just arised.
Old Jun 30, 2022 | 05:20 PM
  #71
nprbob's Avatar
nprbob
1st Gear
any idea what a code 46 means?
Old May 12, 2024 | 02:32 PM
  #72
SerhiiUS's Avatar
SerhiiUS
1st Gear
Default Something weird with mine a/c
I have weird issue. My climate doesn’t start after I start my car. Just light on the auto mode. And it doesn’t respond for any actions for probably 30 seconds. After that it works good. I ran that diagnostic and it showed code 55. Any thoughts?
Old Nov 29, 2025 | 07:57 AM
  #73
batshit123's Avatar
batshit123
1st Gear
Lightbulb Battery drain from something???
I have a #17 code when I check the HVAC codes on my 2015 Lexus LX570. I think it is the code for the engine cooling sensor, but not 100% sure. My battery drains intermittently and when I turn the car off the fan that blows then AC/Heat vents inside the cabin blows. I also found it blowing very lightly for a long time. Could the engine coolant sensor be causing the fan to blow when the car is turned off? I have had it to three indipendent shops and they can find no parasitic drain on the battery and of course the fan didn't blow while it was at the shop. Also, when I pulled out the relay the fan would blow like the car was running. I replaced the relay yesterday and it started this morning, but seemed to be weak. I have replaced the 8 month old battery with best NAPA had to offer and they tested the battery and it is fine.
Just chasing a ghost draw if you have any ideas.
DshngDaryl
Apr 3, 2017 10:03 AM
FlyRyde
Feb 4, 2011 08:50 AM
jpvarghese
May 19, 2008 07:04 PM
mrichman
May 30, 2001 08:12 PM
