Loose Valve Covers Causing Oil/Coolant Leaks?
Old Sep 12, 2005 | 08:42 PM
95SC400's Avatar
95SC400
Question Loose Valve Covers Causing Oil/Coolant Leaks?
Hey all,
I thought my '95 SC400 had blown a head gasket, or at least had a leaky one.
There was oil and coolant leaking out at a fairly alarming rate.
I noticed the bolts holding the valve covers in place were loose so I tightened them (probably not to spec).
Now... no oil leakage and not a drop of coolant lost and the engine idles like new.
Anyone else encountered this???
Old Sep 12, 2005 | 10:10 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Moved to engine section.
Old Sep 13, 2005 | 12:55 AM
rscott's Avatar
rscott
if it was your valve covers leaking, it would explain the oil leaking out and the erratic idle, but does not account for the missing coolant. Double check the two places where it would be obvious that you have a blown headgasket.
1: do an oil change and check to see if the oil is milky
2: Drain the coolant from the radiator to see if there is oil floating on the coolant
If those are normal, you probably dont have a blown headgasket. If you can see the oil leaking out see if you can trace where its from. Remember the headgasket is between the block and the head while the valve covers simply sit on top of the head. A compression test would probably be a good idea to confirm it is not a blown head gasket.
on a side note, if it was just the valve covers loose, pick up a new gasket and replace the valve cover gasket since it will continue to leak otherwise.
Good luck with it. it sounds like you have a very time consuming project on your hands
shah123
RX - 1st Gen (1999-2003)
Aug 18, 2022 02:58 PM
Kinger
May 11, 2019 02:23 PM
Ishinc
Feb 11, 2019 01:29 PM
wing0
17
Dec 14, 2011 11:11 AM
lrobi
Feb 2, 2005 06:24 PM
