about the espliers
Old Jul 16, 2005 | 05:59 PM
96sc3's Avatar
96sc3
Default about the espliers
hi,
is a 2 inch drop with espliers and tt rims with 235 and 285's going to rub?
thanks guys
Old Jul 17, 2005 | 12:22 PM
mrshabo's Avatar
mrshabo
bryan, my car is dropped more than that with the same rims. I don't have any probs.
Old Jul 17, 2005 | 03:45 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
Espelirs will drop it more than 2" (well, on my Soarer it did). 235's will rub at full lock and at speed up front, but normal driving it's not bad. I've got 265's on the rears and it doesn't rub at all. I will be getting rid of mine though as it's too low for Aussie speedhumps and general driving around
Looks nice though
Jose
Old Jul 17, 2005 | 03:55 PM
mrshabo's Avatar
mrshabo
what rims were you using? I had the tt rims and i dropped more than 2 inches no prob.
Old Jul 17, 2005 | 08:30 PM
Kilo's Avatar
Kilo
I have Espelirs with 18s - 235s in the front and 265s in the rear. I dont have any rubbing issues.
Brian - If you'd like, you are welcome to test your TT wheels and 285s on my car.
Old Jul 18, 2005 | 04:08 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Me? I'll answer it anyway
I'm running 18x8.5" wheels... planning on fitting 19x8" (or 8.5") front and 19x9.5" (or 10~10.5") rear, but then again I'm changing my suspension as I've been warned by the popo
Old Jul 18, 2005 | 07:53 AM
buuzy's Avatar
buuzy
You guys with the Espelirs, did you install the camber kit?
Old Jul 18, 2005 | 07:57 AM
plex's Avatar
plex
1UZFE/2JZGTE
I used to rub in back before I had my fenders rolled 265 rears on 18x9.5 with +35mm offset. Camber kit nah its not my daily for much longer.
Old Jul 18, 2005 | 09:39 PM
96sc3's Avatar
96sc3
oic, well.. i guess i will conduct a physical test,.,. on kyles car,.,.
for some reason, even with stock suspension with some weight in car if i drive over a bump it rubs cause my rear tire gets scuff marks,.,.
dunno,.,.
thanks for all replies,.,.
Old Jul 19, 2005 | 02:27 PM
Kaukau's Avatar
Kaukau
Smile EspelirASD vs Eibach Prokit
Hello everyone here
I am running with OEM springs with front 235/45/17-8.5J (potenza) and rear 275/40/17-9.5J (sumitomo). I have a rubbing issue on my rear tires. My car just got an old springs. I guess the best tires fit for SC300 would be front 235/40or45/18 8.5 or 9J and rear 255/265/40/18-10or10.5J. In order not to have a rubbing issue. Otherwise we need to bend both side of tire house end arch. If SC carries 19inch rims or greater, riding will be limited and not recommended to drive a normal driving condition. A car cannot run faster in straight and corner with 19s. (I tried before with my friends car and also he told me the same thing. He is running with 18s now) Of course, at a glance, bigger rims get better looking on sc agreed.
I am planning to change the springs both front and rear. I wonder any advantages changing to Espelir rather than eibach? I prefer not so stiff riding. If any recommendations changing springs, please let me know. Of course lower the looks better than a bit lower. I want to lower down my car soooon...[sorry my broken English...]
Old Jul 23, 2005 | 11:04 PM
mrshabo's Avatar
mrshabo
Ah, that's why you rub. You have aftermarket rims. Bryan and I have tt rims and he shouldn't be rubbing at all since I have the same rims as him and lowered a lot more than him. You know why you have marks? Probably because you have a blown shock like you told me. Anyways just drop in some tein basics and call it a day
kaukau, your probably rubbing on those sizes because of your offset. Those sizes should be fine with the correct offset. If you are going to change your springs, i'd suggest you change your shocks too. The old shocks won't last long with the new more aggressive springs that you put in(also the ride quality will be really bad because of this). You don't want to go through the trouble of having to swap them out twice or paying double the amount for labor.
Old Jul 24, 2005 | 04:44 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
WIth a lower offset you shouldn't have a problem with the tyres sizes you have mentioned, as I had 235/45/17's and 255/40/17's before on +38mm offset. No problems whatsoever.
About the springs, I can't say anything about Eibach as I haven't experienced them, but the Espelir's are the softest riding spring that I have experienced (they are currently on my Soarer).
VJZ
Feb 24, 2009 03:15 PM
DavE713
Jun 15, 2005 04:12 PM
silversprucesc3
Apr 27, 2005 02:31 AM
Sowara30GT
Feb 15, 2005 10:28 AM
