Adding Horsepower
crush bent 2.5in = something like 1.5in HAHAHAHAHAHA i hope thats not the way u went lol
Mandrell piping is bank and the best, but bent larger piping is dirt cheap and effective also...Power difference between the two is not noticeable but the bends need to stream lined.....That is my take from experience...
the whole problem with crush bent piping is not the diameter that it necks down to, it's the way air flows... in the exhaust, you want a constant velocity, and consistently lower pressure along the route...
with crush bent exhaust, you have specific areas of high pressure right before the bends, and after, areas of extreme low pressure... not good for flow...
it also has to do with the way air flows... air will flow with minimal tumble and turbulence in a smooth pipe, however, once it comes to a restriction, it will be very turbulent, and reduce flow even moreso than the new diameter of the pipe...
