how's it going guys listen up , im trying to up grade my fuel system. right now i have a good deal on the stock 550cc tt injectors, well they drop into my car? Also i was trying to change my fuel filter on my car, an i bent the line's by acedent can i buy after market one's...an if yes from where? also how big are my stock injectors........lexus sc400
Sorry I am not firmiliar with the SC400 fuel system, but I know that the supra turbo 550cc injectors are a side-feed injector, and the SC300 injectors are a top feed, so they aren't compatible there... But possibly the sc400 uses side-feed? I am not sure. If so you will need 8 of them!
why are you upgrading your fuel system? it doesnt need it...
you need top feed high impedance injectors or low impedance with appropriate resistor pak
may i remind you that this is a complete waste of money and that I'd bet serious cash your car will be SLOWER because it will never be perfectly in tune
aftermarket lines? I'm guessing you bent hardlines... if thats the case, then you'd be better off buying OEM hardlines for the location that you bent them... upgrading to SS lines would cost you a lot of cash; and would be pointless on a stock SC400
