Alignment Issues
Old May 19, 2005 | 03:32 PM
marcus428's Avatar
marcus428
Well I took the car to another mechanic today and he swears my problem is with the shocks. The shocks are shot. He checked the bushings and confirmed what the other mechanics found. Namely that the bushings are good. Both the LCA bushings and the steering rack bushings. So, tomorrow I'm getting the shocks replaced. Hope this fixes the problem. So far I've gotten: new tires, replaced a frozen front right brake caliper, replaced the left rear ball joint, had a front end aligned and, had the 4 wheel alignment done three times - and I still have the same problem. I'm running out of money!!
I'll let you know if replacing the shocks fixes the problem.
Old May 28, 2005 | 09:41 AM
marcus428's Avatar
marcus428
Ok. I had the shocks replaced with KYBs. Car rides better but after one day of driving, the car started to wander again. Brought it back and they realigned the rear end. Most of the fish tailing went away but I still have a wandering front end. We'll see if the alignment holds but my guess is that the rear end will go out again. Mechanic swears the bushing are good.
Yep, the rear end is acting up again. I guess I need to start listening to you guys and just replace the LCA bushings and steering rack bushings whether or not the mechanic says they are good!
itr206
IS - 1st Gen (2001-2005)
16
Jan 10, 2013 03:07 PM
lexusben
Suspension and Brakes
Nov 22, 2011 09:36 AM
bacardi
Apr 9, 2011 05:16 AM
vwynn
Jun 5, 2009 05:03 PM
Kharizma
Apr 29, 2006 01:32 PM
