HELP! TPS setting on SC400
Old Mar 19, 2005 | 10:41 AM
gnats's Avatar
gnats
Default HELP! TPS setting on SC400
Any info on setting the tps on the '95 SC400 would be wonderful. Methods, specs whatever you can give me.
Old Mar 19, 2005 | 11:01 AM
JTJerryls400's Avatar
JTJerryls400
THROTTLE POSITION SENSOR
THROTTLE POSITION SENSOR ADJUSTMENT
_______________________________________________________________________________________________________________________
Clearance Between Lever Ohmmeter Reading at
& Stop Screw Terminals IDL & E2
SC400
.016" (.40 mm) .............................. Continuity
.026" (.65 mm) ........................... No Continuity
THROTTLE POSITION SENSOR (TPS)
Turn ignition off. Disconnect TPS connector. Using a DVOM,
measure resistance between specified TPS terminals in appropriate TPS
SPECIFICATIONS table.
plug for tps have 4 terminals form top to down: vc, vta, idl, e2
TPS SPECIFICATIONS TABLE
TPS Terminals Conditions Ohms
VTA & E2 .............. (1) Zero ............... 200-800
IDL & E2 ......... (1) .016" (.41 mm) ..... 2300 or Less
IDL & E2 ......... (1) .026" (.65 mm) ......... Infinity
VTA & E2 ...... Throttle Valve Fully Open .. 3300-10,000
VC & E2 ................... ................. 4000-9000
(1) - Clearance between throttle lever and stop screw.
Old Mar 19, 2005 | 11:03 AM
FaceUT's Avatar
FaceUT
Perhaps this link will be of help... It's from a 92 LS400, but I'd be willing to bet it will get you very close...
TPS Calibration
Good Luck!
chillchewy
Apr 19, 2022 12:11 PM
DrAtomica
Nov 29, 2015 12:49 PM
frankjames
May 12, 2009 06:00 PM
Lexs400
Feb 18, 2005 08:43 AM
LB Lex
Maintenance
Jan 11, 2003 03:19 AM
