Iso Shock Info For Eibach's
From: Sideways on the Yellow Brick Road! < Thats KS!
OK, I have Eibach springs on the way for my sc400 and am wondering what shocks I should go with. Will they work fine with my stock shocks or do I need something else? What will give me the Lexus type ride but still improve cornering? Any feed back would be great.
Later,
Scott M.
Later,
Scott M.
I don't think your car can have the "lexus feel" once you lower your ride. Are you running with SC eibachs? or Supra eibachs? I'm running on some KYB AGX Adjustables on my Supra TT Pro-Kit and they're real good.. Just make sure you don't go with KYB GR-2's those are just $#!T.. Tokicos are also good.. change your shocks when you install your springs.. original shocks aren't meant to last over 60k miles.. even if your shocks are still good before you lower it, you should change them anyway. Lowering springs on stock shocks make the shocks die even faster. so might as well get charged for labor from your mechanic once and get both jobs done at the same time then doing springs only and coming back for shocks soon after.
-Ken
-Ken
www.intellexual.net
PLEASE use the search.
This topic has been beaten to a pulp.
You wil discover much more info that helps you even better than a simple question
