HELP. Need cheap ways to make my new car better.
Originally posted by C-Web
Looks pretty good to me. Guess I'd also need to paint my calipers red to make it look like this!
Hey Aaron, how many coats of black would you say is necessary for the calipers? and how many coats of clear? I plan to do this to my brakes next month when I put my wheels on...
I just sprayed 2 coats of gloss black. No clear. Looked fine. I did 'em while changing my brakes, so I sprayed a coat, waited about 2 minutes, sprayed another coat and the mounted them wet (carefully). I sprayed pretty thick coats (yeah I know it's a no-no, but hell, they're calipers with a stamped finish, not a hood or something) so that probably helps. I'll take pictures if you're interested. Literally though, it takes just a couple minutes. I even did it once without even taking the calipers off. Just pulled the wheel, stuck a little newspaper in there, sprayed, then put the wheel back on. Cake.
Thanks man, yes, I'd like to see pics...and I'll probably be doing this soon. I want to use caliper stickers too, any advice? I don't want the damn things to fall off or melt off in a day...you remember who makes this high temp paint? I have Kragen, Pep Boys, Auto Zone, all that crap around here....what city are you in anyway? I'm in West LA...
Originally posted by aliga
http://tunedparts.com/
dang! I just tried and looks like the site is trippin'...just my luck...
Best thing you can do with your car to make it perform better is to restore it to factory spec and make sure the car is in good condition. Do that before making any mods.
Ral
Ral
Re: HELP. Need cheap ways to make my new car better.
Lastly, someone recommended changing my bushings. The car has almost 100K mi. on it, and this guy said they probably need to be replaced. Does anyone know how much this might cost (and if it’s worth it)?
Once you settle on parts then it's up to you to figure out the best course of action to take off your lower control arms and get the old bushings torched out and the new ones pressed in. I understand that taking the control arms off is no big deal, torching them out is the PITA aspect of the job. Find a shop with a press to put in the new bushings. I know for me the job will run $240 parts and labor. $156 on OEM bushings, $60 for my buddy to remove the 2 lca's, and $5 per bushing (there's 4 of 'em) for the machine shop to torch out the old and press in the new! I will have this done sometime near Halloween as my lca's are making noise everytime I reverse!!!
