SC300T Vs. SC400T
Fred are you sure? 3.0 divided by 4.0 is .75. Which mean 3.0 is only 75% of the 4.0. Therefore the 4.0 is 25% larger than 3.0. Slup me twice if i am wrong again.....
Thus, you add 1 liter to 3 liters.
1 out of 3 is approximetely 33%.
Final formula is (33%)(3 liters) + 3 liters = 4 liters
Please bring a number 2 pencil and calculator on Friday, we will have a short quiz then
I'm happy someone is finally stepping up to the plate and Turbo'ing the SC4. Is this being done solely as a one-off project or is this being designed with the potential of turning it into a marketable kit? Don't get me wrong, I don't want to slow down developments by asking a bunch of questions that will impede progress, I'm just wondering if the final bulls-eye to this project is to share the wealth from your fruits of labor or to simply do it b/c it hasn't been done (at least "done correctly" as all CL'ers would agree with).
Anyway, keep up the good work. And good luck.
Peace,
Dix
Peace,
Dix
Originally posted by verylost
To make 4 liters out of 3 liters, you need to add 1 liter (4-3 =1).
he's actually right... 3 * 33% = 3 * 1.33 = 3.99
25% larger than a 3 liter engine would be 3.75 liters
but anyhow, it has more displacement, and 2 more cyliners so who really cares
Originally posted by VSsc400
eeks.. bad math + tuning = kaboom
slap slap
slap slap
verylost + any flammable = kaboom
Have I not told you the time I set myself on fire or the time I blew up my computer?
Got some time and material at home and did some prototyping. However, i couldnt finish it because my welder gas went out. Right now the SC400T look very raw, but once its grinded down and coating. It will be like day and night. Here is what i got:
Here is a finished product after its high temp coated. These pipes are for my LS400T. Looks a lot better
33.33%... great... that mean with the V8... you will make 33.3% more than your 2JZGE motor at a given boost.
Cooler charger = more power at any given boost level (same engine).
Improved efficiency = more power at any given boost level (same engine).
So, it is too early to compare the 2 engines. That said, in theory, all things being equal (planets aligned etc) a 4 liter engine should make 33% more power than a 3 liter. Or to confuse some further... the 3 liter should make 25% less power than the 4 liter
