Thanks for the reply guys. Actually I ment calipers instead of rotors. My bad . If you have an 18' wheel, does it also need to be a high density wheel? And do you need the LS rotors or can you use the existing SC rotors?
Thanks for all the help
vaki2
a low disk 20 inch rim probably wouldnt clear. so its not about the rim size u need a high disk rims. most likely it will fit if the spokes curve outward enough. but i can tell you most the cheap ebay rims will not fit. volks and other well known names seam to fit.
They are a direct bolt on the only tools needed are, LS400 rotors, bleed the brakes, get a set of rims that can clear the brake calipers and your good to go.
so,
will this LS400/LS430 brake rotor and caliper upgrade work with IS300 wheels on a SC300? Sorry if ? been answered, I'm new here and just wanted to be sure .
