Diagrams to remove PSP
Old Feb 19, 2004 | 08:08 AM
dapilot's Avatar
dapilot
Default Diagrams to remove PSP
Hello, I am working on replacing the power steering pump on my 92 SC300. Is there anyone here who could scan or upload the directions and diagrams from the repair manuals on how to replace it?
Thanks!
Old Feb 19, 2004 | 01:53 PM
abboushi's Avatar
abboushi
welcome and use the search its awesome just put in power steering pump youll get a lot of hits.
-abboushi
Old Feb 19, 2004 | 04:58 PM
dapilot's Avatar
dapilot
Thanks, I did a search also but I wasn't able to find the diagrams and instructions from the repair manuals.
Anyone have these?
Thanks!
Old Feb 19, 2004 | 09:01 PM
philauldridge's Avatar
philauldridge
Default power steering pump
honestly, this is a really simple task! It should be pretty obvious, first remove the serpentine belt, disconnect the hoses (being prepared to capture excess fluid) and remove the mounting bolts!
You'll probably find it easier if you remove the battery. After replacement, fill the pump with fluid, exercise the steering back and forth, lock to lock, several times (to bleed air from the system), and top up the fluid as necessary.
Good luck!
rGavint
Apr 17, 2026 09:22 PM
WickedLex
GS - 1st Gen (1993-1997)
Nov 3, 2009 01:22 PM
Neucorp
Oct 21, 2009 02:03 PM
bertjnovak
Oct 9, 2003 08:58 PM
