AEM v2 MAP Sensor errors
Old Apr 14, 2025 | 12:17 PM
udfxrookie's Avatar
udfxrookie
Default AEM v2 MAP Sensor errors
I have a 97 SC300 with the 2jzge na-t on an AEM v2.
I have all the wiring appearing to be correct, getting all signals BUT the MAP sensor.
I bought the AEM 30-2130-50 50 PSIA or 3.5 Bar MAP Sensor Kit straight from AEM since the first sensor had a bad plug (pin broken inside connector)
and I'm getting:
MAP Volts @ 5.09
MAP as Load @ 35.3
because its in error mode (voltage above 4.9 I believe is when the error hits)... HOW AND WHY lol??
I ran a ground straight from the connector maybe 6 inches from the sensor to the frame to ensure it has a GROUND.
Checked the 5v sensor power wire and it's getting 5v.
Ran a brand new wire from the connector to PIN 62B on the ECU.
I have in the wizard AEM 3.5 Bar (PN 30-2130-50) selected.
Also get the same values when I just unplug the MAP sensor connector from the MAP sensor.... values don't change.
What in the world could be the issue?
Old Apr 16, 2025 | 05:52 PM
udfxrookie's Avatar
udfxrookie
New update.... GM style MAP does exact same thing... I'm going to pull the pin completely out of 62B, then I should have NO reading there at all I'm assuming
and if I do....does that mean a crap ECU box? Wrong pin?
Old Apr 19, 2025 | 10:57 AM
udfxrookie's Avatar
udfxrookie
So I disconnected 11B which is the +5v
I clipped 62B about 3 inches out of the harness from the AEM EMS so I had a pigtail to clip onto
62B is providing 4.9v-5.09v when reading it with a multimeter....
If I'm not wrong 62B is a signal pin and should only be receiving voltage not providing it... WTF could be wrong?!? =(
LSneewb
Aug 19, 2024 02:45 PM
Tlynn420
Apr 21, 2022 01:20 PM
99SC42
SC400 / 300 Classifieds
Jul 22, 2012 05:41 PM
bryan767
Sep 20, 2010 03:47 PM
