SC300 Ran at first, now it doesn't
Subscribe
Feb 27, 2025 | 03:25 PM
Recently got this 1993 Lexus SC300 from auction. We were told it ran but struggled to stay operating. When we brought it home it started up just fine. But a couple days later I go out to turn it on and she won't start.
We have replaced the fuel pump, fuel filter, and fuel pressure regulator. Anything helps.
Some things I've checked.
-Battery
-Fuel Line
-If a signal is being sent to spark plugs
-Ignition Timing Mark
-Timing Belt Looks fine
Reply 0
Feb 27, 2025 | 04:31 PM
Quote: Some things I've checked.
-Battery
How did you check the battery?
Quote:
-Fuel Line
Checked how?
What do you mean by signal? You checked for spark?
You mean with a timing light? Why did you replace the fuel pump?
Did you read through this thread?
https://www.clublexus.com/forums/ls-...capacitor.html
Reply 1
Mar 2, 2025 | 06:38 PM
FIX: there was heaps of coolant and fluid in the spark plug valley (don't wash your engine bay)
Reply 0
Mar 11, 2025 | 05:13 PM
Quote: FIX: there was heaps of coolant and fluid in the spark plug valley (don't wash your engine bay)
Check for a coolant leak at the throttle body. Previous owner of mine had done some work and forgot (or lost) two nuts that clamp the throttle to the intake runner and caused the same coolant accumulation you described.
Reply 0
Mar 12, 2025 | 05:27 PM
If you think it is a fuel starvation issue search for fuel pump ecu, they are known to have failures and cause intermittent bad running.
Reply 0
Mar 13, 2025 | 02:25 PM
In addition to the fuel pump ECU, if you have no history on the main ECU have that included in your research…
Reply 0
Subscribe
