Combination of 400's components
Old Nov 29, 2003 | 06:03 PM
2JZSoarer's Avatar
2JZSoarer
Question Combination of 400's components
hey yall...I have a few questions about using 400's parts....
I am planning to put injectors from 400 models and the MAF from a 400 model....but the question is ....does it has to be a certain 400....or it could be a SC400 or LS400 or is this swap can not be done at all....so..that's my 1st question..
then...if I DO have those 440cc injector and the 400 class MAF...I probably do need to adjust some setting with a S-AFC right...???have anyone of yall did this swap???
thanks guys...that's all for now...
Old Nov 30, 2003 | 08:44 PM
Fred Smith's Avatar
Fred Smith
Are you saying you think the SC400/LS400 has 440cc injectors?
Cos they don't.
Old Dec 1, 2003 | 05:16 PM
2JZSoarer's Avatar
2JZSoarer
well...I wasn't really sure about the size of the 400's but that's the very next size above 330cc...I think..but anyway...does the MAF of the 400's really have a bigger flow?...I do know a few of yall 300 guys have the SC400 MAF...but I think all of those guys are turbo
Old Dec 1, 2003 | 08:31 PM
Fred Smith's Avatar
Fred Smith
The 400 AFM is used by the 7M guys as well, for its greater flow, and different electronics.
The 400 gets its extra fuel over the 300 by having more injectors, not bigger ones. If you want 440s, look at a Mk3 Supra or a JDM Mk4 Supra.
Old Dec 2, 2003 | 04:17 PM
2JZSoarer's Avatar
2JZSoarer
so what if I use the 400 AFM but keep my 300 injectors...I do have to adjust my fuel right???being I have more flow w/ the 400 AFM....
thanks
Old Dec 3, 2003 | 10:04 PM
Fred Smith's Avatar
Fred Smith
I dunno.
This is my IMPRESSION from how MA70 Supras use it..
I think the 400 AFM actually reads a lower voltage for the same airflow. That is, the MA70 ecu sees the MA70 AFM going "4 volts!" and it knows "Oh, OK, that's 250cfm" (example numbers).. whereas the UZZ30 AFM says "4 volts!" and it actually means "300cfm". I think. The reason I think this, is because the MA70 guys switch from 440cc injectors to 550cc injectors, and the AFM swap is like a remap for them. You get what I mean? An added bonus is the body of the AFM is bigger too, so it's a slightly smaller restriction.
Of course I could be totally wrong. A good place to research it would be in the 86.5-92 forum in Supraforums. Probably find a fair bit of info there.
Old Dec 4, 2003 | 02:58 PM
2JZSoarer's Avatar
2JZSoarer
thanks anyway
Corban D.
Dec 31, 2008 03:52 PM
horent135
Dec 22, 2008 10:56 PM
tuninghaus
Oct 5, 2007 05:57 PM
zygotesoup
Jul 4, 2007 10:50 AM
IceMan530
May 23, 2006 01:13 AM
