Sc300 fuel issue
Old Aug 11, 2024 | 12:48 PM
Palency's Avatar
Palency
1st Gear
Default Sc300 fuel issue
I recently bought a 92 sc300 and it starts but runs super rich and floods the cylinders, first I thought it would’ve been the ecu because I read that that’s the major problem with these cars but I got it rebuilt and the is still the same I did a compression test and it builds up slow and caps at 140-147psi except cylinder 3 which is 90psi
another issue is when I crank the car to see if I fixed the problem fuel leaks into the oil
I’m wondering if I should change the fuel rail and injectors with my gs300. Just looking for advice here can’t afford to get it towed to a shop right now
Old Aug 15, 2024 | 08:55 PM
RXRodger's Avatar
RXRodger
Sounds like maybe you have an injector dumping fuel. First guess anyway.
Old Aug 16, 2024 | 08:31 AM
Turbostar's Avatar
Turbostar
Yep, sounds like a stuck injector. Check those first.
JOEBRO
Jan 29, 2020 12:31 PM
sc3002jzge
Sep 22, 2011 01:37 PM
HakanUras
Apr 6, 2003 10:30 AM
