SC300 Windows won’t roll down
Old Mar 6, 2024 | 05:16 PM
llax's Avatar
llax
2nd gear
Default SC300 Windows won’t roll down
For some reason my driver and passenger windows will not roll down. I noticed that the ECU-IG fuse keeps instantly blowing every time I put a new one in. The window switch gets no power to it, and I checked all the wires that go in the door jamb to the car. Anyone have any other ideas?
Old Mar 7, 2024 | 08:38 PM
RXRodger's Avatar
RXRodger
If both are not working and you know you have power to the main window switch panel, you probably have a broken ground to the door. My 96 had the same issue and it was a grounding issue. I couldn’t find it so I ran another ground and both windows then worked.
Old Mar 7, 2024 | 09:02 PM
llax's Avatar
llax
2nd gear
The window switch has no power getting to it. Should I just make my own ground and connect it to the switch itself? If so which pin/what color wire.
Old Mar 8, 2024 | 09:21 AM
Turbostar's Avatar
Turbostar
Where is the ground to the door? I'm having a power door lock issue, and it could be that.
gurble
Aug 7, 2020 08:52 AM
Tasty
Feb 24, 2010 09:05 AM
gotparts?
Jul 18, 2007 05:51 PM
gundaman
Sep 26, 2005 02:35 PM
johntran
Feb 25, 2004 08:30 AM
