Sc400 issues code 24/31
Had codes 24/31 swapped out maf with a cheap Amazon maf while mine arrives
cel light went away but runs horrible
can’t attach the video too large but it’s now smoking and rough idle
Hello,
Not particularly sure what you expect from a cheap Amazon unit frankly, it is a pretty precise instrument, and in those older generations, there is no backup to rule out erroneous readings, taking them as a fact, which is likely what causes all the troubles you run into. Quite literally any used working MAF sensor would be a better option.
Hope this helps and best of luck!
Qwertyui1
Mar 30, 2017 11:05 AM
jeromeg1
May 13, 2007 02:26 PM
