Parking brake won’t disengage
Old Jan 13, 2024 | 11:19 AM
Aus10Sc3's Avatar
Aus10Sc3
6th Gear
Default Parking brake won’t disengage
I have an auto 92 sc300, I never use the parking brake however I moved my car to prep for a big storm and thought it would be a decent idea to use it just in case, afterwards even when I put the brake all the way down the light stays on, as well as when im driving I hear a squeaking coming from my rear rotors, I dissembled the parking brake handle and sensor, and even when I manually push the sensor all the way down it still stays on, as well as losening the brake like I’m still hearing a squeaking
Old Jan 15, 2024 | 05:23 AM
Tallyhoe's Avatar
Tallyhoe
Check your brake fluid level and rear brakes for a possible seized caliper.
Old Jan 15, 2024 | 05:47 PM
GAsc300's Avatar
GAsc300
yes, the light goes on when e-brake engaged; it also goes on when brake fluid in reservoir is low. Top off fluid if low, keep eye on rate of change and investigate cause if continues.
jonas's RX
Aug 1, 2022 01:16 PM
NoobExe
Apr 4, 2022 01:16 AM
Luke27617
Jan 28, 2012 10:25 PM
JohnnyCake
Oct 25, 2008 12:43 PM
IStreefidy
Dec 7, 2006 12:56 PM
