Fuel Pulsation Damper Issues
Old Oct 3, 2023 | 11:49 AM
IndigoSC's Avatar
IndigoSC
5th Gear
Default Fuel Pulsation Damper Issues
I need some help I recently did some manifold work and needed to disconnect the fuel rail well I didn’t have new washers for the fuel pulsation damper and have zero clue where to find anything so i tried to replace them with some copper crush ones and now its pissin fuel is there by chance a torque spec Im missing out on or a different washer to use? Please help asap need to get this car driving again so I can get to school tomorrow 😭
Old Oct 3, 2023 | 01:12 PM
New copper washers need to be annealed (google it) or they will never seal. Since you are working with a system involving gasoline BE CAREFUL. I'm assuming the washers are the correct size.
Old Oct 3, 2023 | 01:40 PM
IndigoSC's Avatar
IndigoSC
5th Gear
The washers I bought from the parts store are M12 and the part is M12x1.25 so those are correct as for annealing i never annealed any of my brake lines crush washers so I didn’t think to do that here
Old Oct 3, 2023 | 01:43 PM
Depends on the washers I've used brake line copper washers that leaked instantly had to anneal them. But if you don't think that's the problem then try something else.
Old Oct 4, 2023 | 01:38 PM
RudysSC's Avatar
RudysSC
Lex2k is correct - if you put normal washers from the hardware store in there they're never going to seal. Make sure you get properly sized "crush washers" from an auto parts store. They're annealed so that they "squish" a bit to create a tight seal. Swap those out and you should be in good shape.
JimH2
RX - 3rd Gen (2010-2015)
12
Apr 6, 2012 06:48 PM
archangels
RX - 1st Gen (1999-2003)
Apr 6, 2008 10:20 AM
koreanpers
Oct 9, 2005 01:49 PM
