RZ Model (2023-present)
Lexus RZ Maintenance Schedule
Old Dec 30, 2024 | 05:27 PM
afadeev's Avatar
afadeev
Default Lexus RZ Maintenance Schedule
In case anyone else wonders what to do with a maintenance reminder that will pop up every 5K miles.
Basically, it's mostly BS, but the mileage will trigger a "Maintenance Required" warning light that you will have to reset yourself, or waste time driving to a dealer:
Standard Lexus Service Schedule
The Lexus service schedule operates on intervals of 5,000 miles each, which is the equivalent of 6 months drive time if your Lexus is your daily driver. While the following intervals can generally be applied to all the vehicles in our current lineup, you’ll want to double-check your owner’s manual for your own car’s schedule.
6 months or 5,000 miles
  • Rotate tires and adjust tire pressures as required
  • Reset maintenance reminder light
  • Road-test vehicle
  • Check installation of driver’s floor mat
  • Inspect and adjust all fluid levels
  • Visually inspect brake pads, calipers and rotors
12 months or 10,000 miles
  • Road test vehicle
18 months or 15,000 miles
  • Replace smart key battery*
  • Clean air conditioner filter
  • Inspect axle shaft boots
  • Inspect ball joints and dust covers
  • Inspect brake lines and hoses
  • Inspect engine coolant
  • Inspect exhaust pipes and mounting
  • Inspect rack and pinion steering assembly
  • Inspect steering linkage and boots
30 months or 25,000 miles
  • Road test vehicle
  • Check installation of driver’s floor mat*
36 months or 30,000 miles
Old Dec 31, 2024 | 07:44 AM
ZeroRZ's Avatar
ZeroRZ
7th Gear
going in for mine in a month or so. i hope they know there's not much to rotate~
going to see if they can disable qi charger.
fitiam4me
NX - 2nd Gen (2022-current)
Dec 29, 2024 10:11 AM
sajack
LS - 5th Gen (2018-present)
Mar 17, 2023 10:30 AM
MH1313
ES - 7th Gen (2019-2025)
32
Sep 13, 2022 06:58 AM
calijapan
Sep 3, 2017 02:49 PM
