ABS Sensor problem?? - 99 RX300 AWD
"When you completely turn the steering wheel to either side and hit the brakes, the ABS seems to consistently come on"
Others have had this problem before and I don't recall anyone getting away with a sensor repair. Do a search on this forum for some more detailed info.
Problem can be solved by simply cleaning the sensor/magnets (unlikely as they should fail in straight line), but you never know it could be the connector being stretched.
On the other hand it can be as bad as needing a new brake-modulator.
A safe bet would be to spend $100 or so and let Lexus diagnose it for you.
Salim
ps: How are the tires? It could be the abs is telling you that it detected a skid.
If for instance it only occurs under heavy braking, wheel fully turned, and no other time, then I would even venture to say it's "normal." How are the tire conditions, are they bald perhaps? If you're fully turned to one side and jamming on the brakes, the two wheels are not spinning at the same rate per say, and so the ABS is monitor wheel spin and lock up, so it might just be misreading the wheels.
If it happens on most instances, then I'd say bring it to Lexus and have them look at it.
Owner: "For some reason when you completely turn the steering wheel to either side and hit the brakes, the ABS seems to come on. Nothing major though."
Me: When you say that "ABS comes on", do you mean the ABS light just comes on or you can actually feel ABS engaging?
Owner: "The latter. It's really strange how it kicks in but the ABS doesnt flash on the dash. I was reading online they it could just be dirt too. I only notice it if im parking (thats usually the only time the steering wheel is all the way in the locked position) and im going a little quick."
https://www.clublexus.com/forums/rx-...ake-pedal.html
mikey00 has pointed out a few of the most talked about issues. How prevalent are they? We really do not know.
One thing you must keep in mind is that the parts are expensive and the dealer labor rates run about $100/hr rounded up by half hour.
An AC repair will be $1xxx.00 [guess]
Brake modulator $7xx.00 [another guess]
transmission $5xxx.00 [another guess]
Door lock repair $5xx.00 [another guess]
If you have the RX checked by a mechanic, [lemon busters etc] you will be spending $60.00 or more. Giving the dealer $100 may not be bad investment.
One more thing, the RX brake system has a diagnostic port and the dealer may be the only one capable to read it.
Salim
ps; Lexus are not inexpensive to maintain. A tad below the German luxury but at the top of Japanese imports.
Last edited by salimshah; Mar 26, 2009 at 07:53 AM. Reason: door lock estimate was 10x off
So if any one is considering a vehicle without warranty, I would say put away $1500 or so as needed repairs and it may have to go upto $4000 if some one got a vehicle with serious problems.
The stress on transmission is lot less in ES. The issue has been that although the transmission has been "proven" but in a low profile vehicle.
If I was looking for Lexus sedan, my choices would be the LS, IS or the GS4
[large(lexus flagship), small-sporty, mix of both]. ES is a fine choice but a bit boring.. and this comes from some one who drives a RX.
Salim
Let say im about to pull into a parking spot and turn the wheel all the way to the lock position, i get feedback from the brake pedal and it feels like the ABS kicking in. The ABS light does not flash and the ABS doesnt kick in otherwise unless it's actually doing its job.
I think im going to replace the sensor and take it from there. What else could it be?
