2025 RX engine temp variation
Old Dec 31, 2025 | 05:45 PM
Lexusguy254's Avatar
Lexusguy254
1st Gear
Default 2025 RX engine temp variation
2025 RX 2.4L turbo, non hybrid. I notice on the highway that the engine temp varies sometimes as much as 30-40 degrees. Specifically going down to 180F then climbing back to 206-208F. Today I noticed it get as low as about 170F. I also sometimes hear the cooling fans kick on and then off, but I don’t notice a reduction in temperature. Anyone else experienced this? Is this normal?
Coolant reservoirs are at the full mark.
Old Jan 1, 2026 | 01:22 AM
mathjak107's Avatar
mathjak107
mine hovers around 206-208 most of the time after warm up
Old Jan 1, 2026 | 06:01 AM
PortStLucieRX350's Avatar
PortStLucieRX350
Mine is routinely between 200 - 210, spending most of it's time in the middle of that range.
Old Jan 1, 2026 | 06:14 AM
Carbuff2's Avatar
Carbuff2
What setting have you guys enabled to get those temperature readings?
Ours only displays the BARS to the left of the instrument. Is it because I'm using METER 3?
Old Jan 1, 2026 | 07:31 AM
PortStLucieRX350
I'd have to find exactly how I did it, but there is a setting to select what you want to display to the left and right of the main meter. I had an elapsed time clock there when I took delivery, which was kind of useless, so I picked one that displayed the coolant temp, oil temp, and turbo boost pressure. The coolant temp is what I said was between 200 - 210.
Old Jan 2, 2026 | 02:11 PM
LEXUSturbo24's Avatar
LEXUSturbo24
Underneath that nice boost gauge are two meters on the left and right. On the left you have oil pressure, and the right is oil temperature.
Old Jan 2, 2026 | 05:22 PM
RealWing's Avatar
RealWing
Default Electric control valve
Coolant Temperature should not vary that much after engine is up to temperature. Maybe a problem with the Electric Control valve - which replaces a thermostat.
jim
Old Jan 4, 2026 | 10:33 AM
N4TECguy's Avatar
N4TECguy
I experience this in my 23. My guesses were that it is related to boost, detonation, or maybe tied to intercooler performance. Or it could be that this particular coolant temp sensor is right by the coolant regulator.
Old Jan 5, 2026 | 07:08 PM
KennyJohnson's Avatar
KennyJohnson
Before I joined this forum, I was under the impression that the posters here must be very old (I mean mature) and are only knowledgeable about ancient (I mean not very contemporary) technology. I am proven wrong: instead of old geezers, many posters are geeky sages!! Hats Off!!
Old Jan 6, 2026 | 04:59 AM
PortStLucieRX350
Well, since the average age of an RX owner is mid 60s and the overall Lexus owner is just under 58, you're bound to run into a good chunk of us old curmudgeons hanging around the retirement home parking lot with our RXs. A geek is is still a geek even if the mental Rolodex (for those of you who know what that is lol) may be just a hair slower than it used to be
Old Jan 6, 2026 | 05:21 AM
Carbuff2's Avatar
Carbuff2
The subscription to my Rolodex must have expired...either that or the card fell out and the maintenance guy at the retirement home swept it away.
PICTURES of the temp reading on the dash and detailed instructions appreciated! I'm still thinking that SOMETHING reset when our battery was replaced a week ago.
Old Jan 6, 2026 | 06:09 AM
N4TECguy's Avatar
N4TECguy
It's because they updated the instrument panel for the 2025 model year. I'm using OBD2 readers to get readings off my 23. Car Scanner app integrated with Android auto so it allows readings on the main infotainment screen.
seattleike
Hybrid Technology
25
Jan 7, 2025 02:06 PM
jbl-1985
RX - 5th Gen (2023-present)
Mar 13, 2024 02:37 PM
Wallander
RX - 3rd Gen (2010-2015)
Dec 28, 2015 06:01 AM
spoon808
Jun 18, 2010 12:26 AM
Goldark
Dec 5, 2003 02:47 PM
