2024 RX 350 does not move when accelerator is pressed
Old Jan 10, 2025 | 05:00 PM
rmgmag's Avatar
rmgmag
Default 2024 RX 350 does not move when accelerator is pressed
2024 Lexus RX350 doesn't move when you press the accelerator and feels like the brakes are suddenly engaging. This has happened 2 times after being parked. Have to turn off and restart the car a couple times, then it’s ok. Took delivery in November 2024.
Old Jan 10, 2025 | 05:17 PM
ColoradoDavid's Avatar
ColoradoDavid
I had something similar happen. It seems like it happens when I change the gear position a few times within a minute or so (like P to D, then R), My take is I have confused the parking brake, and it defaults to "on." Unlike you describe, my situation corrects itself after I press the gas petal. I do not have to shut the engine off. I consider my situation normal but shutting off the car seems abnormal
Old Jan 11, 2025 | 10:59 AM
Turbo4's Avatar
Turbo4
10th Gear
My parking brake continued to hold a couple times when I went into reverse while parked on an incline. It released after I pressed on the accelerator. Hasn’t done it lately.
Old Jan 13, 2025 | 01:10 PM
ESh's Avatar
ESh
That’s the hill holder.
Old Jan 13, 2025 | 03:38 PM
ColoradoDavid
Don't you have to manually engage the hill hold feature? I've never used it...
Old Jan 13, 2025 | 04:13 PM
Turbo4's Avatar
Turbo4
10th Gear
My car is set up to automatically set parking brake when you shift into park and release when you shift into drive or reverse. I don’t thick the temporary bill hold was the problem. I’ve only seen that work in drive to prevent unwanted roll back while going from brake to accelerator.
goodyrl
CL Vendor Products for 5RX
Jan 5, 2025 06:44 AM
muccif
RX - 4th Gen (2016-2022)
Feb 5, 2021 07:44 PM
skiracer
Sep 17, 2018 04:06 AM
SY GOLD
NX - 1st Gen (2015-2021)
Feb 12, 2017 07:56 AM
baskooot
Dec 10, 2005 10:50 AM
