Lugging the engine?
Old Jan 24, 2024 | 12:02 PM
menphix's Avatar
menphix
9th Gear
Default Lugging the engine?
Got my 2023 RX 350 a year ago. I have been observing a behavior that the transmission seems to like to select a higher gear than what's appropriate, and this leads to the car sometimes "lugs" the engine.
For example when driving around 20MPH on a slight incline, the car shakes and lugs the engine. I downshifted once and it's showing 3rd gear, which means the car was on the 4th gear before, which I believe is probably too high for that particular situation. I also noticed this when turning at low speed.
I've talked to the dealership and of course they said everything is fine and can't reproduce it Now I resort to two solutions: either manually downshift when this happens or switch to sports mode when I get started, but of course it'll be nice if we don't have this issue at all ...
I'm curious if it's just me or if other people have noticed this, too?
Old Jan 24, 2024 | 05:05 PM
Urlik's Avatar
Urlik
Nope, never have felt it was lugging. Sure it’s quick to upshift but every automatic is.
Old Jan 24, 2024 | 07:19 PM
BLUKTY2's Avatar
BLUKTY2
I too have not had this problem. Please keep us posted if/when you find a solution. Seems to me that something is not quite quite right.
Old Jan 25, 2024 | 03:32 AM
jsch222's Avatar
jsch222
Disconnect the battery for 5-10 minutes. Then reconnect. This will allow the transmission ecu to reset and relearn. Worth a shot
Old Jan 25, 2024 | 03:57 PM
703's Avatar
703
no it doesn’t. And it hasn’t for the last 12+ years on Toyota/Lexus vehicles. ECU has persistence storage.
Old Jan 28, 2024 | 02:20 PM
tolson37's Avatar
tolson37
no lugging on mine - it's in the gear it needs to be always and shifts awesome
Old Mar 7, 2024 | 10:43 AM
menphix's Avatar
menphix
9th Gear
OP here, visited the dealership today and told them about the issue again. They did some more diagnostics and applied an ECM update:
L-SB-0056-23 - MY23 RX350: Hesitation/Non-linear Acceleration From A Stop
I haven't driven it too much but it seems better for now. Will circle back and update the thread once I drive it a bit more.
mattd860
RX - 4th Gen (2016-2022)
Sep 2, 2020 10:26 AM
ItzFilyO
Jun 7, 2019 02:49 AM
ryoo1257
34
Jun 3, 2014 09:36 AM
mseanmc
Apr 2, 2012 06:39 PM
gp1200x
RX - 1st Gen (1999-2003)
19
Apr 6, 2003 01:32 PM
