Vibration at 80 MPH after 5k Service
Old Jan 8, 2024 | 11:15 AM
omar33's Avatar
omar33
Default Vibration at 80 MPH after 5k Service
Took my '23 RX350H for its 5k service. They rotated the tires and I think thats when these vibrations started. Most likely theory is tires are out of balance, any other ideas before I get them road force balanced? From what I read online, typically out of balance tires are not felt if they are in the rear and therefore I think the rear tires from the factory might not have been balanced correctly and when they got moved to the front thats when I could feel it. I could not find any missing weights on the rims either.
at 65 mph, car is perfectly smooth. its only around 78mph+ that you can feel it. Tire pressures are all 35 psi, checked them myself.
Old Jan 8, 2024 | 12:55 PM
1slowes250's Avatar
1slowes250
Not sure why they don't check the balance on the tire when they rotate them. Obviously it takes time and that's money, but it sure could eliminate issuess.
Old Jan 9, 2024 | 01:46 AM
ggebhardt's Avatar
ggebhardt
Sounds like tire balancing would solve the problem.
Old Jan 9, 2024 | 07:37 AM
Klamalama's Avatar
Klamalama
This is why In never rotate the tires (except while moving). Don't mess with perfection.
Old Jan 9, 2024 | 10:04 AM
mikemu30's Avatar
mikemu30
If the rear tires were out of balance, you'd feel it in the seat of your pants. I too typically avoid tire rotations as the dividends paid are minimal compared to the potential drama.
Old Jan 9, 2024 | 11:21 AM
lexusnyca's Avatar
lexusnyca
Never rotate the tires if the car is dialed in from the factory. They may not last as long, but the earlier replacement cost is worth the lack of hassle to get the car dialed back in with steering, balance, etc. I am in my 60s now, I've never rotated the tires on any car I've owned.
Old Jan 9, 2024 | 12:50 PM
WellsB's Avatar
WellsB
I've always rotated my tires per manufacturer recommendations. Never had it cause an issue. Sounds like rotation just revealed an issue here.
swscott530
Aug 16, 2018 02:46 PM
User21c
GX - 2nd Gen (2010-2023)
May 8, 2018 06:43 AM
Johnhav430
Jul 6, 2017 09:10 AM
filmdork
Jun 9, 2017 11:28 AM
