Phone Holder?
Old Jan 8, 2024 | 11:05 AM
happy1977's Avatar
happy1977
RAM x-mount is what we have for our other vehicle and works well as you can place the holder close to eye level.
Old Jan 8, 2024 | 11:21 AM
WellsB's Avatar
WellsB
We considered a suction cup X-Mount for the passenger side, but my partner decided on a weighted dash holder.
Old Jan 8, 2024 | 12:27 PM
WellsB's Avatar
WellsB
Originally Posted by tblaney3
A video shows this better. But with very little pressure you can see how far the mount pulls out the vent molding. The weight of an iphone pulls this out by itself.
I just checked mine and found that the trim moves very slightly if I put a lot of force on the mount. It doesn't move enough to be of concern. After 4,200 miles, I'm very happy with the mount. I have a Galaxy S21u and my partner has a similar sized I-Phone.
Old Jan 8, 2024 | 04:33 PM
madmax24's Avatar
madmax24
Talking
Originally Posted by WellsB
I use several apps that are not Android Auto compatible, such as an Altimeter, Dr Prius, and Torque OBD II dashboard. I wish they were compatible, but I don't see that happening any time soon.
If you are using an Altimeter App, you probably need to slow down a bit. :
Old Jan 8, 2024 | 04:37 PM
WellsB's Avatar
WellsB
LOL!!!
I like to see my elevation when going through mountain passes. I never leave the ground in the Lexus, lol.
Old Jan 10, 2024 | 06:36 PM
madmax24's Avatar
madmax24
Old Jan 11, 2024 | 08:35 AM
Klamalama's Avatar
Klamalama
Used to have a Pro Clip that attached to the far side of the console trim on my 2014 Infinti Q50. It was solid and attached easily. I think our console edge would also be suitable but they don't make one for that location.
Old Jan 11, 2024 | 08:38 AM
WellsB's Avatar
WellsB
I use a ProClip mount in my Ford Focus. I wish they made mounts for the current RX. We used a CD slot holder in our 2013 RX that worked great.
Old Feb 2, 2024 | 07:36 PM
Scientifix's Avatar
Scientifix
Just installed an A-Tach 50484 mount and 10101 phone holder. Looks pretty good to me, and seems fairly solid. Time will tell.
I am thinking of getting this for my wife's 2024 RX. 1) Where the mount attaches to the vent, is there a tape/adhesive that holds it in place or is somehow force locked physically? 2) Does it block the vent controls? 3) I am thinking of getting it with the wireless QI charger phone mount for my wife's iPhone, the mount you have got doesn't charge correct?
Old Feb 2, 2024 | 07:41 PM
Scientifix's Avatar
Scientifix
Oh this is what I was planning to get. I'm wondering if the MagSafe/magnetic mount which requires the phone to be stuck to and pulled away constantly is causing this to happen. As opposed to have a basic holder where the phone just rests and the removal doesn't result in a "pull away" force ...
Old Feb 2, 2024 | 08:46 PM
WellsB's Avatar
WellsB
1) There is an adhesive strip, that prevents it from moving, but its mostly a mechanical/physical lock.
2) It doesn't block the vent controls or air flow if the vents are aimed toward driver and passenger, respectively.
3)My mount does not charge. I personally don't like wireless chargers because they cause the battery to heat up more than wired chargers, thus shortening their life. I keep my phones a long time though, often four years.
I'm up to 7,700 miles on the mount with zero issues. There is a Galaxy S21 Ultra or an iPhone 13 Pro Max in it anytime the vehicle is being driven.
Old May 8, 2024 | 03:05 PM
Patc2024's Avatar
Patc2024
1st Gear
Default Magnetic Phone Holders 2024 RX 350
Does anyone know a good magnetic phone holder for a 2024 Lexus RX 350. My old one does not work. Thanks...
Old May 8, 2025 | 03:39 PM
ShrimpBeefFriedRice's Avatar
ShrimpBeefFriedRice
Default Phone Holders
What are all of the methods you're using told hold your phones aside from vent mounts? I hate can't mounts since I don't want not air during the winter blowing on my phone and I don't like putting weight on the vents repeatedly.
I can manage using the center cup holder unless we're using them, so looking for another option that's not tacky or has me trying to get adhesive on the dash.
Old May 8, 2025 | 04:42 PM
ColoradoDavid's Avatar
ColoradoDavid
Check out https://www.proclipusa.com. Pricey but custom made for specific models. Not sure what the offer for the RX but I have them on other cars. They
work great and will outlast the vehicle.
Old May 8, 2025 | 05:01 PM
Carbuff2's Avatar
Carbuff2
If you are not adverse to 'sticky-cup' suction cups, Scosche sells several varieties that would adhere to the triangle 'vent' window or windshield.
We have them in several cars.
When the seasons change, the mounts can fall off, though.
