Aftermarket carplay on 2017 RX350
Old 06-18-19, 04:57 PM
  #586
kmare
kmare's Avatar
Default Startup time
How long is everyone's startup time? I find majority of the time its a cold start (40s). Sometimes is near instant, resume from sleep kind of thing. No idea what the trigger is for each behavior. Thoughts?
Old 06-18-19, 05:22 PM
  #587
leedoobert
leedoobert's Avatar
Originally Posted by joeguan3rx
Mines is working working and I only have Bluetooth to carplay and not to Lexus or android box. It works the same wired or wireless. This is recommended by Cosmo.
The android / carplay uses aux for audio so as Long as you keep audio source as aux you can do everything in Lexus interface, music from carplay won’t be interrupted. The same goes for back up camera and parking sensors. You can use factory nav and carplay music at the same time. Oem Nav voice and carplay music will play.
Originally Posted by jjj666
Me too, I only have phone connected to CarPlay via Bluetooth, music and google map voice work perfectly
Thank you guys! I deleted all of the extra bluetooth profiles from my iPhone and re-paired my iPhone to CarPlay only. I also set my AUX to external (not sure if this made a difference), and now my Google Maps audio works perfectly in conjunction with my Spotify app! The music actually fades out into the Google Maps audio when I approach a turn! Very OEM!
After the bluetooth reset and re-pairing, my wireless CarPlay connection seems more stable too
Old 06-18-19, 09:11 PM
  #588
joeguan3rx
joeguan3rx's Avatar
Originally Posted by mirkee
This is all too complicated for me and it obviously has a way to go before being fully functional. I'll look at it again in a year. In the meantime, you'all get all the kinks out. :-)
Not sure which part you refer to as too complicated. Shipping only took 3 days from HK to Boston. I installed mine in 30 minutes (thanks for awesome posts here I read all of them prior to starting installation) and this is my first try. I was instantly a happy man. The next few days were just getting familiar with it and optimizing setting to my preference.
jjj666 (06-19-19)
Old 06-23-19, 05:21 AM
  #589
kmare
kmare's Avatar
bumping my question from earlier.
How is everyone's startup experience? My box seems to cold start 90% of the time -- which takes about 40 seconds each time to fully boot up. I find on occasion that the device will warm boot, which is near instant. I have no idea under what conditions the box will warm boot -- looking for others experiences on the startup?
Old 06-23-19, 06:28 AM
  #590
jjj666
jjj666's Avatar
I think I have similar problem. Don’t know what’s the trigger. Hopefully it’s the software problem and can be fixed by a update
Old 06-23-19, 06:45 AM
  #591
qvtruong
qvtruong's Avatar
Mine warm-boots 5 times before it cold-boots.
Old 06-23-19, 06:48 AM
  #592
kmare
kmare's Avatar
How fast is warm boot? I do see 5 / 1 in the product specs, so your experience makes sense. I'm going to reseat my wire harnesses and see if that resolves the issue
Old 06-23-19, 06:50 AM
  #593
qvtruong
qvtruong's Avatar
When it warm boot, it's like instantly cause it boots from sleep. I wish there is an option to make it always go to sleep like that and only reboot when I want to.
Old 06-23-19, 04:12 PM
  #594
Gottspd
Gottspd's Avatar
Well I have to say that I’m pretty disappointed in this device. I had my first lengthy drive (5+) hours each way with the device installed and it was horribly unreliable. In fact it was so poor that I ended up just using the standard Lexus interface for most of the drive home. The problem was that every few minutes it would lose the connection and I’d be staring at the connect the device screen. Cosmo, the idea behind this is great but in that I have over $600 in it plus a load of time, well, I’m frustrated.
Old 06-23-19, 04:32 PM
  #595
joeguan3rx
joeguan3rx's Avatar
Have you deleted all existing Bluetooth pairing (iPhone, carplay, android and Lexus) , iPhone network reset and pair only by to carplay? My connection has been rock solid since Cosmo recommended only bt pair with carplay.
Old 06-23-19, 07:36 PM
  #596
Gottspd
Gottspd's Avatar
I use my phone with several bt devices (including my watch), so that’s just not a reasonable option.
Old 06-23-19, 07:52 PM
  #597
qvtruong
qvtruong's Avatar
I have my phone with 2 apple watches and headphones, but it's working just fine. Probably reset your network setting?
Old 06-23-19, 07:54 PM
  #598
mirkee
mirkee's Avatar
I should stress that I don't even have a Lexus at this time but I will have one in the future. I don't really like cars, although I've had 10+ new Mercedes in my life, all before they became such tech loaded cars. I currently drive a 2015 Venza and my wife drives a 2017 MBZ C-300. Having said that, I'm not likely to get carplay until they get all the kinks out. Once they do that, if I buy used, I want trusted mechanic to be able to install a reliable unit. I don't want any more complications. I currently use a GArmin GPS that sticks on the windshield and is very reliable. Love my Garmin lady. My wife has a Garmin SD chip in her Benz and it appears to be as reliable, although I never drive it. Thanks for all the input none the less.
Old 06-23-19, 08:46 PM
  #599
joeguan3rx
joeguan3rx's Avatar
You can repair all your headset and appple watchafter the network reset on your phone. I do have apple watch and headset as well. The key is to keep only one bt connection with your car via carplay, No bt to Lexus and android box.
My experience prior to to do this was that when starting my car, all three systems appear to be a bt phone device and they were completing to connect to my phone and caused issues at the same time.
Old 06-24-19, 05:04 AM
  #600
Gottspd
Gottspd's Avatar
I’ll try this. I did change the aux to external and call quality through carplay via the box is still very poor. My first call with it, the person on the other end said “I can hear myself talking” and then I switched it to the Lexus BT and that worked fine. So I’m a bit concerned about trying to rely on the box for calls. I’ll give it a go however.
Quick Reply: Aftermarket carplay on 2017 RX350
