Gas, HUD, Hatch, Camera button cluster got pushed into the vehicle
I have a 2017 RX450h.
I took my vehicle to get a state inspection and a wash. By the time I got home after running errands, I noticed the buttons were really far into the vehicle. I called the dealership, but since it was around 7pm, they were closed by then.
Could I possible fix this myself? What pieces need to be removed to get to the cluster and socket it back into place?
Luckily I have enough gas to make it a week or so...
After some Chick-Fil-A and calming down for a bit, I managed to fix it myself with relative ease.
The side panel can be easily (and gentle) pulled off. From that opening, it's just re-positioning and pushing the cluster into the socket and making sure it "clicks" into place.
"● If the fuel filler door opener switch cannot be operated, contact your Lexus dealer to service the vehicle. In case where refueling is urgently necessary, the fuel filler door can be opened using the lever in the luggage compartment.
● Using the lever to open the fuel filler door may not allow for an adequate reduction in fuel tank pressure before refueling. To prevent fuel from spilling out, turn the cap slowly when removing it. During refueling, fuel may spill out from the filler opening due to air being discharged from inside the fuel tank. Therefore, fill the fuel tank carefully and slowly." - Page 269
Interesting!
Camera switch/Heated Steering wheel switch
Has anyone repaired their own camera switch/heated steering wheel switch located just below the left most a/c vent and just above the coin box on a 2016 RX 350? My knee kicked the switches in and I can’t get it out. Any suggestions would be greatly appreciated.
Thanks
Thanks
This ClubLexus Forum page with pictures may help you with your issue.
https://www.clublexus.com/forums/rx-...e-vehicle.html
Good Find!
I see the mods made it one now....Good job!
