Ghosting through windshield, Lexus won't help?
I'm having what I perceive to be a rather major problem, but I wanted to come here for a sanity check before I escalate. Just got my 2018 RX 450h, with HUD.
I'm getting a lot of ghosting through the windshield in the evening and at night. What I mean is, every light source has a double image underneath it, almost as bright as the light itself. As you get closer, the double starts converging and eventually goes away as you near. It's visible on street lights, traffic lights, taillights, etc. It's most visible on electronic billboards, or street signs illuminated by the headlights, or those types of longer light sources.
The phone wasn't able to take a super-good photo, but you can kind of see what I'm talking about here. Particularly under the street lights, traffic lights, and the "Taco Bell" sign off on the right behind the street sign. And also the three-point brake light under the bus in the middle of the frame.
I took it to the dealership, and the service person also observed this same thing with the lights in their garage. But the dealership (and also the case manager I talked to with Customer Satisfaction) says that it's performing "within specifications" and have refused any sort of service on it. I don't think it's some sort of hyper-sensitivity on my part; I've not seen this with my 2015 GS, nor my friend's BMW 550i with HUD.
So to you others with an RX: are you getting the same thing? I have a hard time believing it's like this across the board. I honestly didn't expect Customer Satisfaction to come back with "performing within specs, so we're refusing to do anything," so I'm really at a loss right now as to what to do going forward.
Edit: attaching full size photo
You are not alone. I had this issue with my 2015 NX and 2016 RX, both had HUD. Both are original glass. I don't notice it except at night and it's only at certain distances that the double image appear. I think the angle of the approaching light is a factor because I don't see double traffic lights, only oncoming headlights or following tail lights. Either way, not worth ripping out the factory sealed windshield to address this in my opinion. I have seen some members on here that complained got it replaced though (after much back and forth with dealer).
Oldfart (02-08-18)
I have the exact same issue with my 2017 NX 200, F3
I have been trying to get it sorted out with dealership for 8 months with no luck. They replaced the windshield once and problem persists. I cannot drive the car at night time
You can't drive at night??? It's not that bad, it's only some lights ghosting slightly. I think that is truly one of those "mind over matter " moments.
My understanding of this is the coating on the windscreen to repel rain is causing another reflection - remember it's a laminated screen (2 layers) plus the coating so 3 layers of reflections are going on, with the rake of the screen and the lights coming in at the correct angle, bingo you get these reflections.
I need to take breaks when I am driving at night for long hours. The pictures dont do justice because its mostly the brakes and upcoming vehicles lights that bother me the most. I could not capture it with my camera because it blurs at night more. Also the pictures I have show that the deflection is smaller size than the light. In reality its the same size. Driving on the highway during traffic is a nightmare.
The deflection is worse with distance, as the car approaches the deflection gets closer to the actual light. You could also see it during the day when its a bit cloudy.
And to answer the original question, yes HUD can be turned off but as he said above, it probably wouldn't make a difference
Agreed, I also have a 2017 RX350 with all packages including HUD and I don't experience the so called "ghosting" effect. I'll try to take pictures tonight if I use it. Perhaps I've just been ignorant.
Though, it doesn't bug us much. (Good thing?) But yeah it's certainly there but at different perspectives for everyone. My guess is its partially due to the naturally steep angle of the front windshield coupled with the thickness of the usual double layered glass which causes some sort of refraction effect (sorry physics gurus if I stated that wrong)
Ghosting Effect on Windsheild
We have 2018 RX450H F Sport (with HUD). I have used it for a month and starting to notice that the windshield is showing double images of each light during night time. For instance, I see two red signal lights instead of one (the duplicate one is slightly below the actual one). And it happens to almost all light sources as you see through the windshield. The farther the light source is, the easier you can notice this effect. Anyone has this issue? This looks like a huge miss in the quality.
