Touchless Back Door Sensitivity
Old 01-28-18, 08:21 PM
Elation
Elation's Avatar
Default Touchless Back Door Sensitivity
Anybody requested dealer to change the sensitivity of the Power Back Door?
Power Back Door / Touchless Sensor* SensitivityThe sensitivity of the touchless sensor on the power back door can be adjusted as follows:
□Low(Standard)
□Medium
□High
What does happen when you go to the other settings?
Less time to wait or less distance from the sensor?
Old 01-29-18, 10:56 AM
Nail34
Nail34's Avatar
□Low(Standard)
□Medium
□High
I've tried both med and high. It's just the sensitivity, whatever worked for you before will be more likely to work on the first time, nothing else changes. I guess you can say it's faster if it works on the first time rather than the second.
I touch the emblem, so I don't know about distance. It's not a dramatic change.
westfw (08-13-23)
Old 01-29-18, 01:18 PM
ravenuer
ravenuer's Avatar
One of these days I'll have to check what mine is set for....it works about 25% of the time. Otherwise I've gotten used to just using the button above the plate.
ccianciu (08-14-23)
Old 01-29-18, 02:47 PM
mcomer
mcomer's Avatar
The sensor under the Lexus "Arrowhead" is specifically under the top half, do not fully cover the whole
logo with your hand, just the top. If you hold your hand "fingers up" your palm will be over the bottom...
Try holding your hand or elbow across the hatch lid, do not wave around, just hold it there until you hear
the chirp and then move away.
The manual mentions not to coat or cover the emblem with wax or other preparations. We sell a paint
protective and the crew was slathering it pretty liberally over the whole area...made the opening operation much
less consistent. Had to use a solvent to fully clear the dome, window cleaner didn't cut it, and that restored
the magic.
SoCalRX (01-30-18)
Old 01-29-18, 03:28 PM
Elation
Elation's Avatar
I noticed your body (the key fob) has to be close to the door too.
It wont open even though the emblem is your arms reach. I had to move close to the trunk.
Old 01-29-18, 03:39 PM
mssca
mssca's Avatar
Not that close. I was able to open the back door using the touch-free sensor while standing about a feet away from the vehicle (key fob inside my pocket). I have increased the sensor setting to high so I don't know if that has something to do with it.
Old 01-29-18, 03:57 PM
Elation
Elation's Avatar
The arm length is about 2 feet, and the key fob was possibly placed opposite side of my jocket or pants.
I had move a small step towards the car.
Old 01-30-18, 11:19 AM
mikemu30
mikemu30's Avatar
Received 2,571 Likes on 1,829 Posts
Lots of discussion here on this - anyone ever try the button underneath - it works well
Old 01-30-18, 12:13 PM
SoCalRX
SoCalRX's Avatar
the magic.
I've coated my rear Lexus emblem and it works as usual. It's just a matter of getting use to how this sensor works (at least it was for me). Thanks for the elbow method tip as it works well since I have the remote in my pant pocket. I'll have my wife check if this works with the remote in her purse. Great tip!
Yep, I mostly use this method as I use the button on another vehicle we own as well that's situated in the same location.
Old 01-30-18, 12:16 PM
ravenuer
ravenuer's Avatar
It's never failed me!
Old 01-30-18, 12:43 PM
mcomer
mcomer's Avatar
There is a button underneath? LOL
Old 01-30-18, 12:58 PM
SoCalRX
SoCalRX's Avatar
Actually two: one large rectangular black rubber covered button to open the door and a smaller button operate the door locks.
Old 01-30-18, 05:40 PM
mikemu30
mikemu30's Avatar
Button under the hatch for the door locks?? Now that I didn't know
Old 01-30-18, 06:18 PM
ravenuer
ravenuer's Avatar
Me either...I'll have to go out to the garage tomorrow and look.
Old 01-30-18, 06:41 PM
Nail34
Nail34's Avatar
Mine has one button, push it once to lower the hatch and twice to lock the car, it says that on button.
Quick Reply: Touchless Back Door Sensitivity
